Question about Yamaha Portable Keyboard
One key is "silent" (don't play suddenly any sound) What is the cause?
    Problem Solver:
  • 6 Answers
Sometimes with portable keyboards the circuits get overloaded with *** and it mucks it all up just replace it/die
Posted on Jun 23, 2009
While playing through this amp I stepped on the channel changing footswitch and lost all sound from amp. all tubes and pilot light remained on but amp went silent. Disconnecting footswitch and cable f
Plug the guitar on the "power amp in" jack near the "presence" knob.
If you get sound, you have a problem on the preamp. If not, it´s probably on the power amp section.
Its a good start...
Dec 23, 2014 | Fender Hot Rod Deluxe Guitar Combo...
Hello! I have the Kurzweil Mark Pro TWOi piano. Suddenly some keys make strange sounds through the speakers, like distrortion or noise. The speakers seem to be fine, because the demo songs play perfectly....
Try to re-initialize the unit(factory reset). If the keys are the problem then the rubber key contacts need to be cleaned or replaced. Contact a local service center for help.
Dec 09, 2014 | Music
Casio privia px350. My dp started to have mechanical stronger noises when pressing down the keys affected seem wobbly and seem to hit something as if moving sideways slightly. Only tapping the key...
The Previa key construction was a lot better than yamaha\'s, however it still suffered the normal casualties caused by even the slightest \'knock\'. Believe it or not, most damages are caused to DPs when you\'re NOT playing it. For example, transporting - setting up - packing down etc. I used to market Roland and Casio DPs for a number of years. And the most common problem was the \'stuck key\' syndrome (as well as dust on the contacts). I bought it down to the way people, children, adults actually SIT down to the piano to play. Instead of using the piano stool to balance themselves, many people place their hands on the KEYBOARD before they plant !!! NO NO NO :/ That is the prime reason there are key breakages in - pretty much the same place. Children are a classic example when they sit at a piano. They use the keyboard to leverage themselves UP. Because the DP is not on, it doesn\'t make a sound - therefore "it can\'t POSSIBLY my child\'s fault!!" Oh yeah...have your darling angel sit at an acoustic piano and they\'ll be playing 12th Street Rag before they even get their on the seat!!!
Long and short, possibly broken band, slipped hammer - or broken. Here\'s a video which explains how you might be able to fix the problem yourself. Not much to it really...just take your time and don\'t force anything
https://www.youtube.com/watch?v=_uToVbDDVC0
Regards
Sam
Jun 10, 2014 | Music
I have ve a DGX 640. When the play the C, followed by D, the D is silent. It occurs also when I play the black key after its white neighbour.
Possibly a rubber contact switch problem.
Open up your keyboard if you feel confident about doing so.
Remove the rubber contact strip under the faulty notes and clear away any dust ( this can be a cause of the note not sounding ) Swap this rubber ( part 220 ) on attached picture with the one next door to it. If the problem has moved to the next octave then it is a worn rubber contact switch replace ( see link )
If not you will probably need to take to a repair centre as it may be more serious.
Apr 03, 2014 | Yamaha DGX640 Music Keyboard
Rc-50 recording silent wav files
Perhaps your computer's sound card is unable to play back at the bit rate and kHz you are recording at on your (mobile?) recorder. I'm not familiar with the RC-50 but if you are recording at 24 bit for example and your computer's sound card is only able to play back at 16 bit it may not reprosuce any sound. Usually you will get an error saying so. Have you tried different playback software?
Mar 22, 2014 | Boss Rc 50
Korg Microkorg XL Vocoder Not Working (No Sound)
Check the mic and connections all through its input into the unit. I would check the cartridge of the mic for continuity for the reason that (I think but not 100% sure) on this model, I think there has to be sound at the mic or it does go silent in vocode mode. This is how it digitizes the mic and keys together. The played keys cannot put onto pitch the sound it is NOT picking up at the mic. I think there is a problem with the mic.
Mar 07, 2014 | Korg Micro Microkorg Xl Synthesizer...
Im having a problem that alot of other people are having. my 112 is giving off this constant static and crackle. ive been reading that it could be abad jack in the effects loop.if anyone knows exactly what...
Could be a bad jack like you say. Have you changed your guitar cable? Your cable can make a HUGE difference. Can't know exactly which part it is unless its sitting here in front of me...
Sep 03, 2011 | Peavey Valveking 112 - Tube Guitar...
Hi, i have a problem with my casio wk 210 keyboard. when i push a key then the note keeps playing and doesn't stop. i have tried turning off the power and turning off reverb and none of them fix the...
It sounds like the sustain is stuck on as if a sustain pedal is active. You don't mention if you have one, however if you MIGHT have one and you have used a Roland pedal, that brand is reverse sensed and would cause note to remain on.
Jun 14, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
Yamaha 88 key piano grand plays wrong pitches w/ changing volume
If it has a sequencer/ recorder built in, you have the ability to change the pitch/ detune by using some key strokes after initiating the program mode. If your not sure how to do that, try unplugging the keyboard for thirty seconds and push the power button while it's unplugged, then plug it back in. Any better? What model is it.
Jan 01, 2018 | Yamaha Full-Size Keyboard
Yamaha Portable Keyboard Logo
205 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
