Question about Briggs & Stratton Garden
What size spark plug gap do you use on briggs stratton 450 series 148cc
5 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: spark plug gap fpr a
Typical old Briggs flathead "L-Head" engines require about a .030" plug gap.
Posted on Jun 13, 2010
SOURCE: briggs & stratton 450 series 148cc new one it will
Not getting gas
Posted on Aug 30, 2010
rycgl
  • 1545 Answers
SOURCE: A briggs and stratton 450 series 148cc on a moter
More than likely, it is the main jet is partially clogged. That is the brass bolt that holds the float bowl onto the body of the carburetor. Remove this bolt and washer and clean it well. Use no metal objects to clean it.. Make sure the bottom hole and the side holes near the top are clean and clear.Carb/choke aerosol spray should do the job here. Use no metal wires or scrapers on the jet. Clean until shiny, reinstall and try starting the machine.
Posted on Apr 24, 2011
  • 2239 Answers
SOURCE: what type of oil to use for my briggs & stratton 450 series 148cc lawn mower?
Standard oil for the briggs engine is an SAE30 grade
Posted on May 02, 2012
Which spark plug replacement For Briggs and Stratton 300 series 148cc engine
There should be a number on it. If not, just take it to your local spark plug store and match it visually.
Jul 30, 2017 | Briggs Garden
Spark plug gap
How to Gap a Spark Plug - YouTube
? 2:57
https://www.youtube.com/watch?v=IuW3svdqKZM
Oct 15, 2012 - Uploaded by ChrisFix
How to correctly gap a spark plug. This is a fast and easy video on how to gap a spark plug and spark plug gap ...
FAQ: Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonFollow this step-by-step image guide to locate spark plugs in different Briggs & Stratton engine types. ... Spark Plug Type & Gap Chart for Briggs & Stratton Engines. Now that you've found the part you'd like to replace, you can use the chart below to identify the genuine Briggs & ...
Spark Plug Gap - AutoZone
Dec 15, 2015 | Cars & Trucks
BRIGGS AND STRATTON 550 SERIES
Identifying the Correct Spark Plug and Gap
What is the correct spark plug and gap for my engine?
Due to the variety of engine and equipment configurations, your best source for spark plug information is your engine or equipment Operator's Manual. However, the following general guidelines will get you pointed in the right direction.
This guide provides the common spark plug part numbers used in our L-Head and Overhead Valve engines. For information regarding the service/replacement of spark plugs, please visit our Servicing the spark plug FAQ. Please be aware that the size/shape of the spark plug varies depending on engine design.
Briggs & Stratton L-Head Engines
(also referred to as Flat Head or Side Valve Engines)
Sep 29, 2014 | Briggs & Stratton Garden
Why is my 450 series 148cc briggs and stratton lawn mower engine running fine and then when it gets hot it runs with no throttle
Keep an eye on the oil level, it could be sucking oil past the rings and burning it causing the engine to run a bit faster. it may also have a small vacuum leak at the carb or manifold tube, make sure the carb and manifold gaskets are not leaking air. All combustion air must pass through the carburetor exclusively.
Jul 28, 2014 | Briggs & Stratton Garden
What oil to use 148cc briggs & stratton 450 series
main jet clogged and use plain 30 weight oil in it not not 10w30
May 02, 2012 | Briggs & Stratton Briggs Stratton...
A briggs and stratton 450 series 148cc on a moter mower.The engine fires up after priming then dies.The air filter is fine so is the spark plug,could it be the two small springs behind the carbie?
Apr 24, 2011 | Briggs & Stratton Garden
Garden Logo
16 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
