Question about Garden
I am rebuilding a mower deck for a Kubota B7200/host I have a parts breakdown on deck MOD# RC60-72H I CAN'T FIGURE OUT HOW TO REMOVE THE BOSS BLADE FROM THE SPINDLE SHAFT. DOES IT PRESS OFF OR UNSCREW. I REMOVED THE EXT CLIP ETC.
  • 376 Answers
SOURCE: How do I remove the spindle from the deck of a Craftsman mower.
Put your blade back on so you will have some backup on the nut. Wedge a piece of 2x4 between the blade and deck to hold the shaft while you take off the nut. You should do that before unbolting the spindle. If you are just replacing bearings, you don't have to unbolt the spindle at all. Just remove the pulley on top and the shaft with blade attached will slide out the bottom. The botton bearing, however, will be on the shaft and is difficult to get off. I use a bearing splitter to get it down far enough to drive off the shaft.
Posted on Jun 15, 2009
  • 376 Answers
SOURCE: Removing pulleys from 42 inch Craftsman mower deck
Put the blade back on the star on the shaft and tighten it down. Now you have some backup for the pulley nut. You may have to wedge a 2x4 between the blade and deck. THe EASIEST way is get an impact and zip it off. :-)
  • 32 Answers
SOURCE: How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
Posted on Jul 26, 2009
  • 138 Answers
SOURCE: remove pulley on mower deck spindle
These are generally held on with just one large nut, I recommend you use a impact wrench otherwise it mau prove difficult ( you wont be able to hold the spindle tight enough) and certainly you will need a impact wrench to reassemble the spindle
Posted on Aug 22, 2009
bbreton
  • 437 Answers
SOURCE: need to remove pulley from spindle to replace
If you do not the facilities to use an impact wrench, you will need to find to hold the pulley and you a breaker bar with a socket on it to get the pulley nut loose. I would use either"PB Blaster or Deep Creep" penetrating oil and spray it on the nut before you try to take it apart.
Or you may find a professional shop, take the deck to them and may may take the pulley off for a small fee.
Posted on Sep 28, 2009
Need the front deck wheel and swivel for zd28 60 inch deck
Marvin, check the links below for Kubota deck parts.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Parts Discount Online Parts Cheap affordable lawnmower parts
http://www.tractorjoe.com/kubota
kubotaParts Online
Kubota Tractor Corporation Parts
Apr 22, 2016 | Garden
I just bought an old used Kubota ZG 20 48 inch deck... Need to change the blades... What size are the blade bolts and is it left or right hand thread
what do you think we are we can not test the size like you can and should .rightie tightie lefty loosey
Apr 26, 2015 | Kubota Garden
Free lawn mower manuals
http://www.kubota.com/part/parts.aspx
if you start here, you maybe able to find the manual
Jul 16, 2014 | Kubota Garden
WHY WILL MY BLADE NOT WORK ON MY HUSQVARNA RIDE MOWER AFTER HITTING METAL BAR
Sounds like the large nut on top of the spindle may have loosened up or the splines on the pulley are chewed up. Turn the blade and try to hold the pulley on top. If the blade turns and the pulley doesnt, its one of the two things I just described.
Jun 29, 2014 | Husqvarna Garden
Main spindle needs replacement how to
Typical Kubota mower spindles are mounted with 4 bolts. Some have 4 more on a larger support plate. First the belt pulley must be removed, possibly with the help of a jaw-type puller. Then remove the 4 bolts around the perimeter of the spindle. Using a soft mallet or wood block, drive the spindle assembly down through the deck, making sure there is room underneath for it to fall. Kubota sells replacements as complete assemblies which saves a lot of time vs. rebuilding the spindle.
Oct 05, 2013 | Kubota Garden
Kubota b7200
check for safety switches under the seat and on the brake system
Jun 16, 2013 | Garden
Shaft problems
un hook l/h and r/h lift pins from both lift arms , remove front draft arm from front of deck ( it attaches under the muffler on the chassis )
discoonect the blade engage cable from arm if it uses this type or pop the deck belt off the electric pto if the tractor uses this type
you could just spin each spindle without the blade on ( but leave the top pulleys on ) if spindles bent you should see a wobble , if hard seeing it refit both blades and re-spin each spindle and check for quite a noticable variation in blade tracking when each blade is turned through a rev or two
remove deck , remove both mandrell pulleys from the top of thier shafts
remove both blades and use block of wood and knock the blade spindles out of their mandrells from the pulley side
here is website for parts
http://www.outdoordistributors.com/AYP/AYP_Main.html
just click on 917 the select 288280 from the list
it should show parts breakdown
cheers hope it helps
any problems let me know
paul
Aug 01, 2010 | Craftsman Professional 24 hp 42" Yard...
How to remove blade pulley on a kubota RCK40LT mower deck
To remove the two smaller single blade pulleys you will need at least a 5 inch bearing puller (the kind with three legs. There are two sets of bearings in both assemblies, one on the top of the spindle shaft and the second at the top. If you plan on removing the double pulley in the center that takes the power from the engine and transfers to the blades you will need at least a 6 inch bearing pulley. My recommendation is replace all the bearings, cheap insurance in my opinion. Keep notes of what, where, how each item is removed so it goes back in the right place.
May 09, 2010 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
Ignition switch
A kubota dealer should be able to print one for you or go on line with model # etc and you should be able to bring one up yourself. I hope this helps. donnyb60
Mar 19, 2009 | Garden
Lawn Mower Repair
if the mower is a castel garden the blade boss above the blade may be sheared and needs replacing otherwise top cover over deck has to be taken off to adjust timming belt
Oct 19, 2008 | Garden
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
