Question about Janome Sewing Machines
The needle wont go up or down without real difficulty......no thread caught.....motor sounds but no movement
    Scholar:
  • 47 Answers
There are several things that could be wrong in this situation. Depending on how old the machine is and how long it has been since it has been tuned up at a repair shop, it could merely be a lubrication issue. Occasionally, thread will become wrapped around parts of the take up area, or one of the shafts this could cause the machine to lock up as you described. Although unlikely it is also possible that your motor could be locked up it's self. In order to rule out this as the problem, I would engage the bobbin winder, and release the bobbin winder clutch, and then run the machine. If the bobbin winder still works, it is most like one or both of the first two options mentioned. In any case, it would probably be best in this situation to take the machine to a reputable sewing machine repair shop in your area.
Posted on May 14, 2014
snakehead
  • 1074 Answers
SOURCE: Thread getting caught underneath
you need to replace your shukle that holds the tread bobbing below.it is either slack or broken . if it is slack then you tighten the little screw that holds a cover that gives the thread tension .if its broken then replace it.once the thread is slack below it will cause your thread to bundle up.
Posted on Mar 19, 2007
bibleman01
  • 334 Answers
SOURCE: Serger Stuck
The first thing a machine needs is oil. Absolutely soak everything that turns. My upholstery machine sits for a while and it gets stuck too. Believe me you don't just turn it. The tolerence is so close its just hard to get broke loose. Use a spray that absorbs rust. then oil good when done
Posted on Dec 05, 2008
chrismyers67
  • 53 Answers
SOURCE: when drawing thread up from the shuttle needle wont go down
Sounds like your hook to needle timing is off. When you sew through thick materials, a lot of machines have issues where the needle sticks in the fabric but all the internal parts shift and this causes the hook to needle timing to go out. The begging signs of this is skipping stitches. You will have to have you local independent sewing store do this adjustment for you
Hope that helps :)
Chris
Posted on Jun 06, 2010
Testimonial: "thank you"
  • 1788 Answers
SOURCE: Wads of Thread Caught in Singer Simple Sewing Machine
Sounds like you threaded it wrong and kept trying to sew, gently get all of your material out of the machine, DO NOT FORCE, GENTLY ROCK IT OUT OR YOU WILL WRECK THE MACHINE, also watch your dvd and learn about threading from your book. Always, hold your thread ends when you start to sew. If, you cannot find your manual go to www.singerco.com, I have sewn for 50+ years and found that the dvd was very helpful, each machine is different.
Posted on Aug 21, 2010
SOURCE: My bobbin thread will not thread. When I bring
check the bobbin to make sure it's not warped
check the needle to make sure it's not bent-roll on flat surface to see if it roll correctly
make sure the bobbin is in the bobbin case correctly
make sure you have a 3 to 4 inch tail on the bobbin-so the upper thread can pick it up easily
make sure you have a 3 to 4 inch tail on upper thread also as it picks up the lower thread
or you can hold the upper thread with your hand to the side of the machine & use the handwheel to lower the needle as it picks up the lower thread
pull both threads to the back behind the needle
make sure there is no lint or loose threads in the bobbin area
Posted on Sep 01, 2010
Change bobbin
The cheapest, fastest way is to unthread, look in all the thread 'pickup points' and make sure that there are no broken threads caught in the movement, then Rethread according to your machine's manual/diagram. If rethreading does not help, change the needle-sometimes the smallest of burrs, bends, whatever, in the needle can make a machine not work!
Feb 03, 2015 | Sewing Machines
My sewing machine has been working fine but when I changed thread colour and bobbin the motor works but there is real restriction on the needle and it struggles to go up or down at all. Have looked fo
Hi sounds like either some thread caught up somewhere... or the needle tension is far too tight.... I would check for caught thread under the needle plate.
May 17, 2014 | Sewing Machines
My problem is between the needle and the bobbin. The tread continues to get caught just below the needle- inside of the machine. The bobbin seems to be lifting up and thread gets caught beneath the needle
Hi. So is this a horizontal hook? Where is the thread getting caught beneath the needle? Maybe on the hook? Check your upper threading to make sure the thread passes through the thread take-up lever. If thread is not through the lever, it wont get pulled up , which can lead to multiple thread loops getting caught on the hook, not pulling off after the rotation.
Apr 15, 2011 | White Sewing 2037 Mechanical Sewing...
My machine is breaking the thread. I tried changing the needle, adjusting the tension, and different threads. It is still breaking the thread. I took the top cover off and oiled it and the bottom cover...
What needle size and thread are you using? The needle may be too small for the size thread or you are not threading it correctly.
You should also check the bobbin area to see if the thread is getting caught or snagged.
Jul 10, 2017 | Juki TL-98Q
Why does my thread keep breaking and why wont the sewing machine stich?
sometimes the thread can get caught on the spool pin
or on the notch on the thread spool itself
on some machines the thread can come off the thread take up lever
it can also get caught in the top tension area
also check your needle to see if it's bent--roll on flat surface to see if it rolls correctly
there are 3 types of bad needles-bent
blunt--makes a popping sound when going thru fabric
damaged--broke tip
also check your bobbin area for lint or loose threads
check your bobbin to see if it's warped--I've come across some that were warped
check your top thread tension
Sep 24, 2010 | White Sewing 2200 Multi-Tasker
Needle wont go up and down wont stich
Rethread your machine, I think that your thread is caught somewhere, If you need help call Euro Pro customer service
Aug 24, 2010 | Euro-Pro 9120 Computerized Sewing Machine
The machine keeps locking up. i have cleaned the bobbin and hook area. there was not much lint
if your machine has a front loading bobbin case, remove it and then remove the shuttle which the bobbin case fits into. most often there is thread or lint caught in the shuttle race preventing the shuttle from turning (it only needs a tiny piece of thread).
if you have done this check any gear meshing to ensure no lint or thread has been caught in the teeth of the gears.
if the machine sews ok and locks up after a few stitches then it sounds like needle threading or tension causing the problem. re-thread the machine and ensure there is sufficient needle thread tension to bend the needle a little when presser foot is down and thread is pulled through needle.
goodluck,
scott.
Jul 28, 2009 | Kenmore Sewing Machines
Push on pedal, hear the motor, no motion, arggg
it sounds like the belt might have come off the handwheel
Feb 02, 2009 | Brother XL-5130 Mechanical Sewing Machine
Sewing machine problem
I just solved this problem with much persistence and a few possible causes. Mkae sure the thread is good quality and cant shred, at least until problem is fiwed. Unscrew plate behind bibbin and check if there is any caught thread, this happens after bottom thread has been looping. Remove any and replace, wind down the needle to check it goes in the centre of hole.
And probably the most important fix it; the tension;
Have your tension set to zero, thread the machine, and when the foot is DOWN, make sure it is very hard to pull the thread. It should be easy to pull the thread when the foot is UP. If the thread is easy both ways it has not caught correctly in the tension plates, thread it again (and again) until this happens. It shouldn't be possible to thread the machine without it going in the right place, but it is. And make sure when you rethread that the foot is UP until you thread the needle-
Another problem maker I also had to fix; ever so slightly bent needle.
Oct 11, 2008 | Brother Disney PE-400D Computerized Sewing...
Sewing Machines Logo
20 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
