Question about Pentax Optio M40 Digital Camera
How to turn off white balance
This is for a pentax OptioM30
My Pentax K-30 photos are nearly pitch black. Is there something I can do to fix it myself?
We need far more information - lens in use, shutter speed and aperture settings, white balance setting, ISO setting, exposure compensation, lighting conditions, subject matter etc. All of these have a bearing on exposure. From your description, it sounds as if your images are seriously under exposed. Have you looked in the trouble-shooting section of the camera manual ?
Dec 06, 2016 | Pentax Cameras
Camera takes blue photos
You sure you did put the camera to fully automatic? Because I don't know what model you have, I can't check the manual, to see if you could adjust the white balance. It has not much to do with ISO, but with white balance. Sure you did not select something like scene inside. or scene in tungsten?
May 14, 2014 | Pentax Optio Cameras
Pentax optio s10 white balance is isue, unable to adjust camera working fine then all of sudden all white
If you can get into the menu, find "reset" and follow the on-screen instructions. If not, remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Dec 30, 2009 | Cameras
Clouds appear pink rather than white
check the white balance setting. You need to reset white balance each time you use camera whether you are shooting inside or out and for the time of day Auto does not always give you the best results.
Aug 12, 2009 | Pentax Optio S50 Digital Camera
Broken screen
I replaced mine myself. I bought a lcd screen brand new off ebay and they gave me a few simple instructions and I replaced it myself, and I'm a chick!!! It really was easy and cost about $40 otherwise I was told around $90. Just had to buy a real small phillips head screwdriver! Good luck!
Mar 31, 2009 | Pentax Optio A30 Digital Camera
Optio S40 white objects are pink
Sounds as though the white balance is off, check your manual on how to alter the white balance to manual - then change it back to auto. It should fix it.
Feb 12, 2009 | Pentax Optio S50 Digital Camera
Pink pictures
Have you tried changing the White Balance. You can access this by switching on the camera, pressing the Fn button and then the left arrow.
Jan 11, 2009 | Pentax *ist D Digital Camera
Pentax istDS Digital Camera, How to set Custom White Balance in Auto Modes
Custom white balance can only be set in P, Tv, Av, or M modes. The auto modes are, well, automatic. They are all preconfigured and intended for ease of use not configurability.
Nov 08, 2008 | Pentax *ist DS Digital Camera
Pentax optio l 50
1.first switch off the camera
2.then take out the battery
3.clean the inside with a dry and clean cloth
4.again switch on the battery
5.try to select the white balance option again
6.if not,do the process again
it will surely work
Sep 24, 2008 | Pentax Optio 50 Digital Camera
Pentax Optio M40 Digital Camera Logo
20 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
