Question about Tools & Hardware - Others
15hp Briggs Vanguard 1cylinder runs like it's on choke emitting black smoke. What can be wrong ?
    Problem Solver:
  • 7 Answers
The "black" smoke has me wondering... I would suspect that you may have a broken ring on the piston, or even ha hole in the piston.
Several weeks ago I found two of my neighbors mowing lawn and pumping out heavy clouds of smoke. I went to each of them and they told me they just filled the oil. They filled it up until it came out of the dipstick hole. This results in too much oil in the crank case and not enough air, so the engine forces the oil past the rings and then you are burning oil with the gas producing a large amount of smoke. I took my turkey baster and a can to each and removed the oil until it was at the proper level. Then I showed them the dip stick and explained that the oil level must be between the two marks on the dip stick. This situation of too much oil produced a huge amount of smoke, but the smoke was more white than black.
- Joe
Posted on Aug 13, 2014
2 Suggested Answers
Rayvin1943
  • 97 Answers
SOURCE: Briggs 14 HP Vanguard runs well until PTO is engaged
First thing u might want to check is the governor--Make sure the spring and linkage is hooked up properly and the governor is moving freely.
Posted on Jul 19, 2009
Spark plugs foul immediately
Fouled plugs may be caused by oil leaking into the cylinder. Does it smoke when running (cold), are you using up the crank oil. Black smoke is excess gas comsumption, blue smoke is oil burning. If your plug is fouled with black carbon, you are most likely running to rich.
Apr 07, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
I have a 18 hp b&s vanguard engine and it will only run on half choke any ideas
it,s not getting enough gas, your carburater needs cleaned and there's an mixture screw on most engine's hope this helps
Sep 22, 2012 | Briggs & Stratton Electrical Supplies
FC540v Kawasaki john Deere 265, bugs down under load,emitting black smoke & then dies. Works fine without air filter.Carb cleaned, Compression check has 80 lbs
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
Thanks for your attention to this matter.
Aug 29, 2012 | Cars & Trucks
I have a 23 hp Briggs Vanguard that i have to run with the choke a quarter of the way on or it will die. What will cause this to happen?
It is starving for fuel. Replace the fuel filter first thing. Clean or replace the air filter. Also purchase a can of Seafoam or Techron fuel treatment. Follow the directions on the can and put some in a full tank of fuel. After running this full tank if you still have the problem then you may need the carburetor adjusted or cleaned out. I would advise you to seek professional help in accomplishing this.
Aug 08, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
Smoking and loosing power
Blue smoke means engine worn or too much oil in sump.
Black smoke is caused by too much fuel being sucked into carburettor.
This can be caused by a dirty air filter, choke being left on after engine is started or fault in choke system if automatic choke fitted.
Feb 21, 2011 | Briggs & Stratton Briggs Stratton Intek V...
27 horse power briggs on poulan pro. It smokes,
Very likely, the piston rings are badly worn or stuck. There may even be a small hole in a piston. In any case, you will need a major tear-down to repair this one. This is usually caused by lax oil-changes. It might be better to purchase a replacement engine than try to fix everything that could be wrong with the present unit if you take into account parts and labor. Hope this helps!
May 24, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs 12.5hp vanguard stopped n smoke at rear.
Its possible that the spark caused an in-line fuse to blow. Try following the wires from the battery to the ignition switch to the starter. There is probably at least one fuse in that path.
Jul 25, 2009 | Garden
Engine smokes and looses power
Check the air filter, replace.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 26, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Tools & Hardware - Others Logo
51 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
