Question about Samsung 40 UN40D6300 LCD TV
Samsung un40d6300 double picture what part do i need to repair
Would like to buy part i need and install myself
I have a SAMSUNG ST100 camera and 3 black lines are showing on my screen and its not scratched any where. It hasent been exposed to any sun,water nothing that can damage it. Its been put away safely. Can i...
Maria,
As long as the lines don't appear on the pictures (check the pictures on your computer) don't try to repair this. For opening a camera you need to have electronic skills and special tools. Then there still is a chance the defect can't be repaired without exchanging the display or even the motherboard. In both cases I think it is more expensive to repair then to buy a new camera. If you can live with the lines and they don't show up on the pictures, please don't try this yourself.
If you really want to ignore my advice, please visit ifixit.com and see if they already did your Samsung. There they show how to open and close most electronic equipment. They also sell the tools you could need and can help with spare parts. If they are for sale from Samsung.
Sep 01, 2014 | Cameras
I have puchased UN40D6300 samsung led tv from US to india. but it is not working in india with TATAsky hd setup box. STB generating output on 1080*50hz. its giving "the resolution is not supported...
hi,
Check whether the tv's ac input voltage. if it is 110V then it is made for US users only. It will only work with NTSC colour system. Here in India the colour system is PAL.
OK
Sep 15, 2011 | Samsung 40 UN40D6300 LCD TV
My phillip tv has started showing a double picture
Hi
Thanks for using FixYa. The issue is with the convergence ICs going bad and needs to be replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself you can buy and repair it yourself. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 11, 2010 | Philips 60PP9202 60" Rear Projection...
Samsung #HCM553W
Hi, convergence amps have blown, if you have soldering equipment and are proficient at soldering & un-soldering you can make the repair if not you need to calll a tv tech, there is also an alignment that must be done with the original remote once you install the IC`s, if your capable of this get back to me and I`ll look up the parts for you, video-tek
Feb 11, 2009 | Samsung HCM553W 55" Rear Projection...
RCA model P60820BL picture changes to bow tie shape
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left and fuzzy images this is a symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Jan 29, 2009 | Samsung HC-R4755W 47" HDTV
Blurry shadows in red and teal.
Picture look double and the colors red come out the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Sep 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Double images
You need to replace both convergence ICs they are STK392-560 you can get replacement ICs at the following link and they provide free installation instructions with pictures so you can install them yourself. Heres the link.
Jun 07, 2008 | Sony KP-65WS500 65" Rear Projection...
3d function...Samsung HCN653W
You need to replace both convergence ICs they are STK392-040 you can get replacement ICs at the following site and they will provide free instalation instructions with pictures so you can do the repair yourself. heres the link.
Jun 05, 2008 | Samsung HCN653W 65" Rear Projection...
Samsung HC-P4752W 47in", is showing double picture
your Convergence ICs need to be replaced you will need two STK392-010 ICs you can get replacements at the following link, and they provide free instalation instructions with pics so you can do the repair yourself and save about 400 dollars. They also have free online instant messageing while you do the repair in case you need additional help when doing the repair. Heres the link.
May 21, 2008 | Televison & Video
Samsung SyncMaster 710N 17 in. Flat
hi
I am a technician-informatic. I have repaired about 40 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it on eBay.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Oct 29, 2007 | Samsung SyncMaster 710N 17 in. Flat Panel...
Samsung 40 UN40D6300 LCD TV Logo
53 people viewed this question
Henry  Thomas
Henry Thomas
