Question about Whirlpool GW397LXUS Stainless Steel Gas Range
Why does display on whirlpool gr399lxg electric range keeps going blank
When i use my stove, the display keeps going out, what is causing this
SOURCE: whirlpool Electric range model RF386
I had the f5 code displaying on my range also. When I read your comment that power surges can do strange things, I just tried unplugging the range then plugging back in and it cleared the code.
Thank you Tory
Posted on Feb 03, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool electric range model # RF261PXSQ oven not heating
I'm afraid you may have a blown Electronic Oven Control (EOC) board. The EOC controls all the functions of the oven. The surface elements are controlled by individual infinite switches behind each control knob.. That's why the surface elements all work, but the oven does not. A replacement EOC can be purchased on line at searspartsdirect.com. Just type in your COMPLETE model number and you will find it under the "Control Panel Parts" heading as item number 12. There are several listed, based upon the color you need (White, Biscuit, and Black). This is a very simple repair that any do-it-yourselfer can accomplish if you wish to perform this on your own. All you have to do is UNPLUG the appliance and remove the back panel of the console to access.
Before assuming the EOC is defective, however, inspect the board to see if it has a fuse on it. I do not have a wiring diagram to confirm. Some of these boards do have fuses and that's all that it may take to repair it. However, if the board shows signs of burned components, replace it. NOTE: Check for any loose connectors to the board as well.
I hope you find this information helpful. Let me know if you have questions and/or require additional assistance.
Posted on Sep 25, 2008
aborcass
  • 2651 Answers
SOURCE: Error message FSEO appear on display of whirlpool stove
Door and switches
do not agree
1. Unplug range or disconnect power.
2. Check wires and connectors from control to door switch, then from door switch to control.
3. If no damage to wires or connectors, replace door switch.
4. Replace all parts and panels before operating.
5. Plug in range or reconnect power.
6. Press Cancel/OFF key. Program and start the CLEAN mode, and observe for 1 minute to ensure that
operation is normal.
7. Go to step 1 and complete checks.
Posted on Jan 11, 2009
SOURCE: Whirlpool eletric range model RF363PXDW w/F1 display
The manual to this oven is here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203196274.pdf
That should fix almost any problem you have
Posted on Apr 03, 2009
SOURCE: Whirlpool Range Model GR399LXG
Accidently hit the autoclean and then stopped it, Now the oven will not lock so I can't clean my oven
Posted on Apr 09, 2010
Rf365pxmw control panel blank
Do you have the black, white, or biscuit colored control panel?
Feb 22, 2013 | Whirlpool RF365 Electric Kitchen Range
Gr399lxg f1 e2
E2 F1 - UL A/D error(s)
1. Disconnect power longer than 30 seconds.
2. Re-apply power and observe for longer than 1 minute.
3. If failure remains, disconnect power, replace control.Here is the board to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 20, 2012 | Whirlpool RF368 Electric Kitchen Range
I have a whirlpool electric glass top stove (model # rf364pxpq ). our electricity went out for only a moment, and when it came back on, the control panel is blank and the oven doesnt turn on. the stove top...
I just encountered the same problem. Power surge during storm caused the control panel to go blank. I removed the panel to get the part number. Reinstalled control panel and it started working. Below are the steps 1) Turn off breaker 2) Unplug unit 3) Remove rear panel 4) Unplug all connections to control panel 5) Wait 5-minutes 6) Reconnect all wires in reverse order 7) Install rear panel 8) Plug in unit 9) Switch breaker to on position Control panel came on, set clock and all oven functions worked.
Jan 02, 2011 | Whirlpool Kitchen Ranges
What does pf display on stove mean
POWER FAILURE.
Your electric may have gone off.
The breaker may have been turned off and back on.
The range may have been unplugged and plugged back in.
You have loose wires in the range.
You have a defective control board.
One of the above will cause a PF code.
Jul 11, 2010 | Whirlpool RF364 Electric Kitchen Range
Door and switches
do not agree
Jan 11, 2009 | Whirlpool RF364 Electric Kitchen Range
Blank display on Clock/Oven Controls
Control is bad if it is getting power- needs to be replaced. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Dec 01, 2008 | Whirlpool GR460 Electric Kitchen Range
GE JCB909 Range - Blank display
suspect wrongly wired from new
Jun 25, 2008 | GE Ovens
Whirlpool GW397LXUS Stainless Steel Gas Range Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
