Lg tromm wm1812cw no power
Plug in the washer no power won't turn on! Any suggestions?
  • 520 Answers
I have this machine and had the same problem... after verifying there was power to the receptacle (check breaker and install known good device into plug) I was faced with replacing the main board which cost me $150.Any warranty can be checked through LGUSA.com or can obtained through andrewselectronics.com who is an authorized factory parts outlet for LG
Posted on Jun 23, 2009
How to fix an error code "CE" on my wm1812cw lg tromm front loader5
See if the top will lift up, if so there will be a code and test sheet in there that will lead you to fixing the problem. Very easy to follow.
Jan 06, 2016 | LG Washing Machines
Lg tromm wm1812cw dum makes load noise when spinning
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jun 15, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WASHER WON'T Power on
Hello. If the lid switch is defective, your washer may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 24, 2010 | LG WM1814CW Front Load Washer
I have an LG TROMM wm1812cw washer. Out of the blue the machine will not spin or drain. It has given an an error code OE
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 27, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Drum will not spin
I unplugged the machine for 1 hour and the computer reset, and it is working fine
Jan 04, 2009 | Washing Machines
My LG Tromm washing machine WM1812CW keeps coming up with error 0E. how can I fix it.
what do the letters UE mean on my Tromm front load washing machine?? PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I P
Jun 01, 2008 | Washing Machines
Washing Machines Logo
461 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
