Question about Craftsman 34 Hp Garage Door Opener Chain Drive
Managemylife com sears
What is the service charge to replace a logic board, opener still under warranty
Replaced logic board on sears garage door opener, cannot turn light on from wall control
Did u make sure to plug the light in when u replaced the logic board? And u may have three wires been t only two are needed for the wall button ... whats the model number of your opener?
May 24, 2014 | Sears Craftsman LiftMaster Chamberlain...
Wall switch will operate door. Remote would operate door if held next to opener. Replaced logic board but remotes still will notwork at all. Wall button still works. Thanks Adrian
Did you program the opener after replacing the logic board? Press and hold the button on the remote while you press and immediately release the smart/learn button on the logic board.
Jul 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
Error code 6500
*Error Code - [6500]
*Conditions - The PCI bus error is detected by the ASIC.
*Solution (Replacement of listed parts, which are likely to be faulty) - Logic board ***'y
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much can user do instead of replacing the malfunctioning hardware. 6500 is generally logic board error code. If the printer is under warranty, you better ask for replacement.
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much a user can do except replacing the malfunctioning hardware.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 05, 2011 | Canon PIXMA MP830 All-In-One InkJet...
H3 Elite washer.... steel tub is wobbling and cutting into the plastic ring liner. If steel tub or has separated from bearing, is this covered under warranty.... after 4 years.... or not. How expensive is...
rear pulley nut is loose. tighten . if it has been loose for a while pulley may be warped and also tub bearing and spin basket could be bad. dont have your specific model # to know if in warranty . can go to wpl .com and check warranty with your model # or kenmore then go to sears.com . i would use another servicer we waive are service fee if you fix the washer we only charge 65.00 service call. im sure you can find a servicer with a lower service call. thats the highest ive ever heard they will charge you double what anyone else charges.worse case scenerio could be 300-400 dollars if tub, pulley , spin basket need to be replaced. but i say its worth you replacing pulley or checking nut any other repairs for this i would just replace unit. again check your warranty i think the spin basket has a 10-20 yr warranty.
Sep 19, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Model 41a4315-7c wont program remotes but will work with single wall button. has worked for years
That number you are giving is the part number for the logic board and if you cannot program your remotes is the part you will need. It is expensive.
Aug 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Kenmore elite oasis washer 3rd repair
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!
Jun 01, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Only opens when remotes are close
The problem is in the receiver on the logic board. You will have to replace the logic board. You can get a replacement part at searspartsdirect.com. Thanks BB
Feb 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Your Haier fix kit
The Haier fix kit is 3 boards to replace the 3 boards in your plasma. So the only way to get it done is to order from Haier/Sears. Sears knows this! Make them come to your home, it is a warranty issue.
Is the tv black screen with sound? That's usually the problem. The Sears service rep will come out, order the upgrade kit, the kit is mailed to your home, then you notify Sears and they return and install the 3 boards. You can do this yourself when the boards arrive and skip Sears, but only if your comfortable removing the back of the plasma (about 25 screws) and replacing circuit boards.
Apr 15, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Craftsman 34 Hp Garage Door Opener Chain Drive Logo
59 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
