Question about Refrigerators
Lg model LWHD8000ry6 a.c. unit turns on...when compressor kicks in, everything turns off...if Igive a stout tap at the digital display/control head area, it will come back on but did again when compressor comes on
2 Suggested Answers
SOURCE: GE Profile - model PDS22 - constant clicking noise
Yeah, same problem. There are two capacitors that seem to be prone to going out. You can replace the main board, or (if you can solder) replace the two capacitors with slightly larger ones (radio shack mdl number 272-1030 works) just remember to bend them away from the heat sink if you go that route.
Posted on Jul 11, 2009
I turn off unit with the remote. After a few minutes the compressor turns on without turning on the unit. The digital lights do not come on. It still shows the unit to be off. I have to press the the small...
The Relay or the Magnetic contactor is stock up so the contact has always a power. Or your Supply from the relay and magnetic never turn off. Try to tap this to release from being contact. If can be remove replace it. If the supply of the relay has power even if your turn of the unit then your problem is in the electronic control unit. Your need service personnel to do this.
Sep 25, 2011 | LG Electronic Window Air Conditioner
Model GFSF6KEXWW FRENCH DOORS WITH FREEZER ON BOTTOM AND ICE MAKER IN DRAWER. TEMP READINGS SAY "OF"
Hello & Welcome to FixYa
The error should read O FF if that is the error then it means that the unit is in demo mode. To remove error code, refrigerator door must be open. Press and hold Refrigerator and Ice Plus button simultaneously for 5 to 10 seconds or until the display changes. This is NOT the Er FF Error Code. Please get back to me if you have any other questions.
Kevin
Sep 19, 2011 | GE Refrigerators
LG AC compressor problem
Compressor may be locking up. Run capacitor may be weak or loose wire. Sounds like major voltage drop off as unit head pressure increases.
Jun 28, 2009 | LG Heat cool Window Air Conditioner
Kenmore AC Model 25370156000 keeps shutting off and on by itself
If you have just installed this unit in your window for the season, you may want to wait a day or so, for everything in the unit to settle, and try again. You make have shaken it up a bit too much. If not.....sounds to me like it is kicking out on high head pressure. This happens when refrigerant gets too low, or there is air in the refrigerant system. There is nothing you can do to solve this problem, except take it to a repair shop. If I am correct what happens is you turn the unit on, and the fan and compressor start simultaneously, then after a few seconds (maybe up to a minute) the compressor kicks off, and the air gets warm, then the compressor kicks on for a few seconds, and we repeat. This is actually a safety mechanism for the compressor motor so it does not run without refrigerant. (That would destroy the pump.)
Jun 04, 2009 | Kenmore 76129 Air Conditioner
LG LWHD8000RY6 Air Conditioner Not Cooling Room
Remove the front cover of the unit to expose the cooling coil. Put the unit on and observe if there will be formation of frost (ice) on the coil. If there's frost formation, the common cause is dirty cooling coil. Have it cleaned using an alkali base coil cleaner. If the coil is clean, then the problem is the fan motor. It might be turning slow due to copper loss. Have it replaced.
May 28, 2009 | LG Heating & Cooling
Surround sound won't work
Try Googling (sony)(STR-K840P)(manual) without parens.
May 25, 2017 | Audio Players & Recorders
The refrigerator won't cool
The control board either isn't sending the voltage to the compressor, or the compressor itself isn't working. Try unplugging the unit for 10 minutes or so to see if the control board will reset itself. You might also try pulling off the toe kick at the bottom of the unit to see if there is a diagnostic sheet to be found. This may give you some direction on how to put the machine into diagnostics through the digital display.
Mar 14, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
