Question about HP Compaq Presario SR2032X PC Desktop
Maximum supported hard drive size - HP Compaq Presario SR2032X PC Desktop
    Scholar:
    New Friend:
  • 46 Answers
You can utilize any capacity drive with your system. Depending on your operating system you may need to take additional steps to enable any capacity of 2 TBs or greater.
Posted on May 02, 2016
4 Suggested Answers
  • 50 Answers
SOURCE: cannot support an internal hd larger than 1
Vista doesn't have a 1TB limit, however just make sure you have Service Pack 2 installed. (I don't believe SP3 is necessary). you can get it free from microsoft, just do a search on the internet. The motherboard is controlled by the BIOS. Go to your MB's manufacturers site and search by your model # to get the latest bios version and instructions on how to install it. Because it is an HP it's actually going to be easier to just go to hp.com and search for the bios file there.
Posted on Jul 05, 2010
  • 1623 Answers
SOURCE: what is the maximum size
you can put any size hard disk you want in there as long as its sata
Posted on Apr 01, 2011
Geekman
  • 32281 Answers
SOURCE: Hard drive upgrade
This model computer has two SATA connectors.
You can install SATA hard drives to suit your requirements.
1Tb SATA hard drives are readily available.
Posted on Jul 02, 2012
Maximum hard disk size for hp a1610n
Based on The Spec's of your System you have a 250gb Hard Drive however the Maximum size will be less then that due to formatting the drive so you can expect that to be like 10% less then 250gb (just a guess) plus a lot of computers come with a restore partition which is usually around 12gb assuming you leave it factory stock.... Your computer by default will set your Hard Drive to the Maximum size... now as far as how big you can install the sky is the Limit your computer is new enough it should except any size Hard Drive available at the store.
Oct 14, 2013 | HP Pavilion Computers & Internet
Tip
How to solve low memory problems? Normally this warning message shows when you...
Normally this warning message shows when you run many programs same time than the RAM installed on your computer is designed to support. Your can solve this problem by increasing the system paging file size also called as virtual memory. Using this virtual memory windows moving information to and from the paging file for fast processing. This will free up enough RAM for other programs to run properly.
To increase the system page file follow the give path:
Control Panel > System > Advanced > Click on Settings (Under Performance) > Advanced > Change
Here under Drive (Volume label), you have option to select any of your hard disk drive, but the best choice is, select any drive other than C drive for virtual memory.
Set the double Initial & Maximum Size of your Virtual Memory. Here set initial size 700 MB and maximum size up to 1000MB; you can change this size according to the free space available on your hard drive.
on Apr 08, 2010 | Computers & Internet
Hardrive is unknown device in bios
The BIOS determines the maximum size hard disk the computer can support.
The max hard disk size for this model Dell is 80Gb.
To use your 250Gb hard drive, install this Hard drive into an USB hard drive case and use it as an external USB hard drive.
Mar 09, 2013 | Computers & Internet
What is the maximum size of hdd will support for asrock 775vm800 motherboard?
I think the actual size of hard drive is unlimited, certainly Asrock make no claims that there is a maximum size. I would however, to be on the safe side, install only a 1TB drive. You could of course get a larger drive and partition it into smaller partitions, which should bypass any possible size restrictions
Jul 26, 2011 | Asrock 775VM800 Motherboard
What's the maximum hard drive I can install in a Compaq SR1420NX I have a 80 hard drive right now I want to install a larger one. Will this computer handle a larger Hard Drive
The BIOS has a max. hard drive size limitation. Check the manual for the maximum size the motherboard can support.
If the maximum size hard disk it can support then you can add a second hard drive in the computer as a SLAVE hard drive to double your disk space capacity.
Mar 15, 2011 | HP Compaq Presario SR1420nx...
Hi There. I am looking for an Internal Hard Drive to suit a Dell Inspiron 1525 Laptop. Seagate Momentus 5400.3 160Gb ST9160821AS. Where can I get one or is there another Hard Drive that would be OK to use...
I suggest you check the specification of your Dell laptop to see the maximum size hard drive it can support. The maximum size hard disk you can install in the laptop depends upon the BIOS.
Any major brand of 2 1/2" hard drive will work with the Dell.
Oct 27, 2010 | Seagate Momentus 5400.3 - 40GB - 5400rpm -...
Hi i m hems i m upgrading hard disk on my ( acer aspire 1641nwlmi ) laptop hard disk is 160 gb but it's not detecting my new hard disk , my new hard is ok but i have quistion 160 gb is supporting my laptop...
The Aspire 1641 is supplied with a 80Gb hard drive. If the new 160Gb hard drive is not detected in the BIOS then the BIOS cannot support this size hard drive.
Check your manual/specification to see the maximum size hard drive it can support.
You can install the 160Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive.
Aug 24, 2010 | Acer Aspire 1641WLMi Notebook
Supported hdd size
There is no limit on the maximum external hard drive - all it does is plug in with USB. As for the internal... No idea. I immagine it would be better value just to get a external hard drive. Try www.oyyy.co.uk to get them - where I got mine.
Oct 17, 2008 | Toshiba Computers & Internet
Maximum hard disk support
this hard drive size will work with your motherboard but the problem is the size will be detected only up to 130 GB or less, so if you will be using that size of hard drive you will just waste it.. so better use a 120 GB of hard drive or upgrade your motherboard so you can use a 250 GB.....
Hope that helps.............
Sep 01, 2008 | Computers & Internet
Dell c600 latitude Motherboard
The video card is NOT upgradeable.
the system should support a 120 GB HDD
NOTE: This system is old enough to be considered operationally obsolete and not a good candidate for an upgrade. Especially with new portables starting at $499
http://www.dell.com/content/products/productdetails.aspx/inspnnb_1525?c=us&cs=19&l=en&s=dhs
Jul 07, 2008 | Computers & Internet
HP Compaq Presario SR2032X PC Desktop Logo
56 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
