Question about GE Hotpoint 30" Self-Cleaning Freestanding Electric Range - White-on-White
Burners and stove dont work
My hotpoint stove the display and lights apear to work like they should but none of the burners or the stove get hot
  • 22 Answers
SOURCE: Hotpoint stove with f3 code.
Replace the oven control module.It controls the bake and broil including clock and timer functions.
Posted on Mar 31, 2009
SOURCE: GE Spectra range
I just moved into a new apartment and my stove wasn't working properly. After reading the very helpful information posted by kd3ke, I decided to turn off the breaker to my stove, take off the back covering, and check out what was back there. I was experiencing the same problem as posted.... the burner light, oven light and clock were all working however, the burners did not get hot nor did the oven. After taking off the back panel, the cord did have just as he stated, a black, white, and red wire however the plug attatching to the stove did not have cordinating colors. It was just a grey cord with 3 copper wire heads. It seemed to me that the cord was twisted and therefore everything was backwards. Since I was relying on his post, that would explain why the stove still did have some power, just not all, because the voltagages were wrong. I flipped the three cord wires, reconnected them to the stove and then plugged it in and turned on the breaker... everything works now!!! :) I don't know if this will help anyone else since it may not be the same problem if your stove was working properly previously, but it fixed the problem for me since I had just moved in.
Posted on May 24, 2009
jumptrout51
  • 3361 Answers
SOURCE: Two burns dont work and replace burner don't work
Replace the burner switches. They are bad.
Posted on Aug 02, 2009
milten1
  • 1304 Answers
SOURCE: ge gas/prop stove bottom oven burner will not
you will neeed a new ignitior
its a pretty easy repair
take out the racks
take out the bottom of the oven
you should see the ignitor
pull ou the drawer you will see the connection
disconnect it
make sure your very careful with the new one they are very brittlle
Posted on Oct 09, 2009
  • 61 Answers
SOURCE: MY GBP80 RANGE DOESNT TURN ON CLOCK DOESNT WORK
sounds like a bad board when you figure out what part you need check out www.appliancepartssolutions.com
cheep parts
Posted on Jan 21, 2010
How to fix la germania burner?
Guess you mean a kitchen appliance not a cd/dvd burner! The only way to help you giving some advice about how to fix ut is if you tell us the problem you need to fix.
Describe your burner: is it a gas burner or an electric burner?
Had you repaired something similar before?
In any case, watch some youtube tutoriasl to repair a burner
Cooktop Range burner not heating burner light is on GE Hotpoint RCA...
GE Hotpoint RCA Gas Stove Repair Burner is not working JGSP44BEY3BB
Prego Project Fix GE Stove Burner
Stove Oven Range Burner Repair Diagnostic GE Hotpoint Kenmore Sears RCA...
Aug 19, 2015 | Computers & Internet
Can't seem to access Hotpoint Stove Pilot Light?
Your range uses electronic ignition, not pilot lights. For surface burners the igniter sparks when the gas valve is turned to the "light" position. All burners should spark when any gas valve is in the light position. For the oven the ignitor is also electric but does not spark but rather heats up or glows. What is the problem with your range?
Nov 30, 2014 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint electric stove burners wont heat up
Water ingress has taken the trip out i expect. If only clean water, it may dry out and then you can replace the fuse/breaker. If in doubt, employ a service engineer.
Dec 21, 2017 | Kitchen Ranges
I have a Hotpoint RGB745 when i turn the stove on it never gets out of pre heat mode. oven is warm but not hot. top burners work fine
The stove knobs won't turn on the oven. If you've already checked the igniter, take apart the top and look for loose wires. My husband found a loose one going to the control board, tightened it and now things seem to be working.
Dec 04, 2010 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint electic stove, the burners and the oven not working
Is there any sign of life? Does the oven light come on or does the clock work? Just for kicks, go and reset the breaker - it should be a double breaker for a 220V appliance - sometimes half will throw and still leave 110v that will run the light / clock.
Jul 26, 2009 | Hotpoint RB757 Electric Kitchen Range
MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
May 22, 2008 | Ovens
Hotpoint glass top stove
sound as if you only have 120 volts going to the range check the voltage
Apr 12, 2008 | Hotpoint RB787 Electric Kitchen Range
GE Hotpoint 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
