Question about Electronics - Others
Sound lab pro12\400 efx - Electronics - Others
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
Dec 28, 2015 | Precor 546 Elliptical
I want to replace the battery
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Precor Elliptical Models Affected:
  • EFX C524 with serial#s beginning I7, K7, LH, SW, SX
  • EFX C546 with serial#s beginning NF,SZ, IK, IL, IU
  • EFX C546I with serial#s beginning X8, XG, Z2
  • EFX C556 with serial#s beginning NG, SY
When replacing the battery on your Precor elliptical it is important to make sure that the battery terminals are not allowed to make contact with the metal surface of the battery bracket. **Damage to the battery will occur**.
Electrical tape can be wrapped around the battery terminals to prevent them from making contact with the metal surface of the battery bracket.
Battery replacement on the EFX C524, EFX C546, EFX C546i and EFX C556 instructs you to remove the (4) screws that fasten the battery bracket to the frame. This allows you to turn the lower PCA and battery assembly away from the frame so you can slide the battery out of the battery bracket. It may be necessary to remove the nut that fastens the front retaining bracket or "L" bracket in order to slide the battery out of the battery bracket.
Warning Notice for Battery Installation on Precor EFX Ellipticals
Feb 11, 2014 | Precor EFX 546i Elliptical Version 4
Replacing battery
Feb 07, 2014 | Precor EFX 546i Elliptical Version 4
How do I replace the battery on efx 546i
Jan 01, 2014 | Precor EFX 546i Elliptical Version 4
How do i change the battery on a precor efx 5461
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Dec 25, 2013 | Precor EFX 546i Elliptical Version 4
Replacing the battery
You can use the link below to access a service manual download. Please see page 68 for the battery replacement procedure.
http://www.sportsmith.net/images/product_support/precor/Service%20Manuals/Commercial%20EFX/C546i%20(version%203)(AJME,%20AMTE,ATRE).pdf
Aug 21, 2012 | Precor EFX 546i Elliptical Version 4
Precor efx 556
Here you will find parts and other information for the Precor EFX 556.
Repair Parts for Precor EFX 556 Ellipticals SPORTSMITH net
Jan 07, 2012 | Precor EFX 546i Elliptical Version 4
There is a clicking sound periodically coming from the right pedal while I use the machine (Precor 546i). I tried tightening the bolts but the clicking persists. Any thought would be greatly appreciated....
It sounds like it could be a faulty bearing in one of your wheels, a worn ramp or a combination of the two. The following link will take you to our Precor page. Please reference your model and serial number. This will allow you access to the correct parts and manuals for your machine.
Precor Elliptical EFX Repair Parts Belts Wheels Pedals SPORTSMITH net
Aug 06, 2011 | Precor EFX 546i Elliptical Version 4
Scosche EFX work with MOS-FET Amplifiers
CAN YOU E-MAIL ME THE MANUALS FOR THE VOLFENHAG ZX 7150 AND THE ZX 7170 MY E-MAIL IS smas5305@yahoo.com thank you Thomas Anderson
Mar 22, 2010 | Scosche Industries EFX Amplifier Wiring...
I have a behringer djx 700 and i got an efx 1000, and would really help me if you no how the best way to connect it to the mixer my dj setup is 2x pioneer cdj 1000 mk3 1x behringer djx700 1x pioneer...
ok has the mixer got a send and return phono sockets if it has not the efx unit will have to be wired between your mixer and amp.this is not the best way . what does the efx / effects unit do .
Dec 08, 2008 | Audio Players & Recorders
Electronics - Others Logo
112 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
