Question about Sony BRAVIA 55 in. LCD HDTV
How to get service manual
Sony Bravia KDL-55XBR8
  • 2317 Answers
SOURCE: Instruction Manual for Sony BRAVIA KDL 32 P 3000
You will find the user guides in different languages by clicking here.
Posted on May 20, 2008
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
  • 50 Answers
SOURCE: slow moving image sony bravia KDL32M3000
Hello darwin_gabou, My names Dave! You have a bad A/V input board.
Part #: A-1376-788-A
Link to part: http://www.shopjimmy.com/catalog/product/view/id/169673/s/sony-a-1376-788-a-bm-board-for-kdl-32m3000/
Please feel free to contact me if you have any question. I'll be more then happy to answer any questions you may have!
Dave
503-432-9904
Premium TV Tech
www.pleasefixitdave.com
pleasefixitdave@yahoo.com
Posted on Apr 01, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Posted on May 07, 2010
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Posted on Aug 05, 2010
We have sound but no picture
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 467,264 views. 2:30. LCD & LED TV Repair - No Image ...
How to fix sony bravia has black screen - Digital TV - Streaming ...
www.tomsguide.com/forum/56867-4-sony-bravia-black-screen
Aug 19, 2014 - 12 posts - ‎11 authors
Hello, My Sony Bravia TV screen has gone all black. The green on/off light comes on,but no picture appears. The model ... Your solution solved the non picture for live tvbut still no picture (just sound) fir OnDemand. Score. 0. No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
Tv problems picture ok but no sound - HDTV
Sep 8, 2011
More results from www.tomsguide.com
Dec 14, 2015 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
Sony kdl 55xbr8 vertical lines
Check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 02, 2014 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
KDL-55XBR8 every 6th horizontal line is dark to the left and gets normal to the right
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 26, 2014 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
Sony bravia snooze button
What is the problem you faces with this TV? Your problem post has no details about it.
Sep 26, 2012 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
B+ Over Voltage Protection problem Sony Bravia KDL 32S2000
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I have sound but no picture
oh, so that's your problem. I'm willing to bet you have a picture but just no backlight. Now does the screen come on briefly when you first turn the TV on? Or is the screen black at all times?? Turn on the TV, turn off the lights in the room. Take a very bright flash light and shine it one the screen.I bet you see a dim picture. It sounds like you have a backlight problem. Either you are missing 24VDC from the power supply, 3.3VDC "backlight on" signal from the main board, a bad inverter, or a bad backlamp.
May 12, 2012 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
I need a user manual for Sony Bravia KDL-26V4000
Hello Mr.Daniel,
Here's the User Guide in pdf [35685kb] for your Sony Bravia KDL-26V4000
User Guide 2 in pdf[6330kb].
Hope this helps.Thanks!
Please vote this answer if helpful.
Dec 18, 2011 | Sony Televison & Video
Sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Oct 07, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Do not have user manual and need to run setup
Click Sony Support to download user manual of KDL-32XBR6
Manual has detailed info about initial setup.
Mar 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
SONY Bravia KDL-52W3000- Quit
Sony are normally pretty good,you just got unlucky i guess,well at least you still got the warranty.
Feb 03, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA 55 in. LCD HDTV Logo
11 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
