Question about Shark Vacuums
Handle broke on 3027377
Need new handle
Tip
I have a Bissell Total Floor vacuum. The handle release pedal broke so now the...
If your Bissell upright vacuum cleaner is not cleaning like it did when it was new, then you need to provide a bit of maintenance or service. I will tell you how you can do this maintenance to your Bissell vacuum.
First, make sure that your floor vacuum is unplugged. Then you can work safely on your Bissell bagless vacuum.
If your Bissell upright vacuum is losing suction, then the next thing to check is the canister. It is very easy to simply forget to dump the canister.
The while you have the canister out, check the filter inside the canister to make sure that it is not plugged full of dirt. This filter can be difficult to access, but a little persistence will pay off. When you get the bottom of the cup open and remove the filter, use a bit of soapy water to wash out the filter. You can then reassemble the filter into the bottom of the canister.
On the left side of the vacuum there is also a HEPA filter Bissell has there to help filter the air even more. Remove that, clean it also and replace it.
The hose is the next thing to check. You can completely detach the hose from the vacuum. Check the hole at the bottom where the hose hooks up to make sure the hole is not plugged. Then stretch out the hose and run something like a coat hanger through it to make sure that there are no obstructions inside the hose. You should be able to hold the hose up to a light and see right through it.
The last thing to check is your Bissell vacuum belt. If the belt is too loose it will slip and not spin the brush properly. Bissell belts can be purchased online easily, or in many grocery stores. If your Bissell upright cleaner has a slipping belt, it may also be because of strings, carpet pieces, etc… getting wrapped around the brush. Remove the vacuum brush and cut off everything that is wrapped around it. Always be careful of the vacuum belt after you have just used your vacuum. The belt will be very hot just after use.
These steps will help you to get your Bissell upright vacuum cleaner working like new again.
on Nov 08, 2010 | Vacuums
Charger XA2940
Just want to order a new charging cord and batteries for our sweeper.
Aug 12, 2014 | Shark Vacuums
Broken handle
You will need a new handle tube. You can use the included link to find a repair store near you. Oreck Store Locator
Apr 22, 2014 | Oreck XL21 Bagged Upright Vacuum
Control cable broke push and pull broke
Remove the handle assembly by removing screws and sliding off. Remove nozzle housing cover and unscrew fastener at end of cable. Pull cable from handle end out of cable sheath. Slide new cable into sheath and fasten at bottom as it was before. You will need to adjust the cable to the proper location so the transmission works properly in both directions.
Apr 18, 2014 | Hoover Self-Propelled WindTunnel Bagless...
My Hoover Linx handle broke.
Not sure what you mean by a broken handle, but if you mean the plastic is cracking where the handle connects to the main body than I have a suggestion. We have had this happen a couple times and I tried various fixes that did not work. However, recently I found a cheap product that will strength the handle to make it stronger than new. It called Fiber Fix tape (its on Amazon). Wet the tape and wrap the handle. It is a quick set epoxy in a fiberglass like cloth. Dries very hard. Not pretty, but it works great.
Jun 19, 2012 | Hoover Platinum LiNX Cordless Stick Vacuum
I just need the part number for my Guardian Electrolux model C134A i ran over the Hose and that was the part that broke. i need to compare prices so i can determine if it is cost effictive to change the...
The part number for the hose is 47086.
The best thing to do is contact the nearest Aerus Electrolux dealer.
If it's just the switch or handle that broke, it will be more cost effective to have that replaced. If I remember right, the hose costs close to $200 new. A new switch may cost up to $20, but probably quite a bit less.
The nearest Aerus store can be located using the below link.
http://www.aerushome.com/storelocator/
Mar 29, 2011 | Electrolux Guardian Bagged Canister Vacuum
Handle broke off when Vacuuming?
Two screws hold that handle onto the machine. Maybe they weren't installed when the machine was put together.
If it broke part of the dust compartment, it's probably not worth fixing.
If it broke part of the handle you can order a new one for about $30.00. It's part #75765-2.
Dec 01, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Vacuums Logo
15 people viewed this question
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
