Question about Ford 555 backhoe
Is there a seal behind the starter to keep fluid in ?
Fluid leaking behind starter?
Oil leak seem to come from starter. What can it be - main bearing oil seal?
Oil leaking around a starter is usually one of three possible things.
If it is motor oil, then suspect the rear main seal.
It it is auto trans fluid, it could be from the transmission front seal or the torque converter
If you have a manual transmission, it could be clutch fluid leaking from the slave cylinder, or a leaky front seal from the transmission.
Mar 06, 2015 | Cars & Trucks
Is there a seal behind starter?
You have a torque conventer seal out.
May 11, 2014 | Ford 555 backhoe
Check power steering fluid in honda accord 1994
The power steering reservoir (I believe) is on the drivers side just behind the headlight. about mid-way down the side of the reservoir are a high and low mark. The reservoir should be just at or below the high mark when the vehicle is off. ONLY USE HONDA POWER STEERING FLUID. There are certain conditioners and additives in the Honda fluid that keep seals in the system in good condition. Using a generic/aftermarket fluid will cause the seals to shrink and the system will likely develop leaks.
Jan 05, 2014 | 1994 Honda Accord
My 2000 ford has had a clear liquid leak, what can it be?
If it is clear water, and its leaking onto the ground, and you are running the ac, its condensation from the ac.
Aug 30, 2013 | 2000 Ford Mustang
My 2004 ford ranger automatic transmission fluid leaking from the starters weap hole
Remove the transmission & see if the front pump seal is worn,
where the torque converter goes in
Oct 27, 2012 | 1992 Ford Ranger
My 94 Jeep grand Cherokee power steering fluid is leaking. I fill up the fluid and a day later the fluid is all gone.
The lines coming off the unit are probably to blame, one is a high pressure line. Look for leaks around the fittings on both lines.
Jan 04, 2011 | 1994 Jeep Grand Cherokee
There is power steering fluid dripping from the passenger side boot covering the rod that connects to the wheel. Could a simple replacement of the boot be the fix, or is there a problem with the main unit...
No, the boot only keeps dust out of the inner tie rod joint--it is not intended to hold back fluid. The rack will have to be rebuilt with new seals. Sorry. :o(
Dec 05, 2010 | 1998 Toyota Sienna
Ford mondeo 1.8 td diesel, the problem is the power steering fluid is leaking, when i check it look like it was coming from the middle part of the radiator.how can i fix it and what parts do i need to get...
Have a look at the power steering fluid cooler it is just in front of the radiator behind the front bumper. The coolers corrode and leak. Also the seals can go, check for fluid leaking out of the boots at the track rods. Try this procedure :--- 1)Trace the source of the leak. Use a mirror on an extended handle to follow the puddle of fluid on your garage floor to the power steering system. Look on the hoses and gaskets to find from where the fluid could be leaking. 2) Add power steering stop leak additive to your power steering fluid. Lucas Power Steering Stop Additive is 100 percent guaranteed to stop seal leaks. In older cars, the seals shrink, causing leaks. The stop leak makes the seals swell to their original size. 3) Use gasket sealant if the gaskets are old and leaking. Sealant, such as Permatex, is resistant to engine fluids, and will help repair a leaky gasket. 4) Replace the gasket, if the gasket sealant does not work. Thanks. you can rate this solution and show your appreciation.
May 19, 2010 | Ford LTD Cars & Trucks
Transmission fluid leakage from stater motor area. 5.7L Vortec
If transmission fluid is dripping off the bellhousing your torque converter seal is leaking or your transmission pump seal is leaking. Chances are the torque converter seal is leaking since the torque converter is spinning on it any time the engine is turning, the pump seal dosen't move it just keeps fluid inside the transmission. Even though it leaks with or without the engine running I'm willing to bet if you got underneath it with the engine running you will see it leaks more with the engine running. Now if either seal is leaking it will require the engine to be removed from the transmission to get to the seal. Sorry but this isn't going to be a cheap quick fix.
Apr 01, 2009 | 2001 Chevrolet Express
Fluid leak around starter
It may be a rear crank seal, or oil from the torque converter (automatic) or the input seal on the transmission. Check your fluid levels in your engine and trans. A visual inspection will help also. you could remove the inspection panel on the bottom of the trans bell housing. As for the clunk I would be leaning towards more of a starter issue for that.
Dec 08, 2008 | 2002 GMC Sierra
Garden Logo
16 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
