Question about Worx GT WG150 10 in. 18 Volt Cordless String Trimmer w/ 1 battery
Worx battery charger issues
What is the problem with the worx charger and battery for a 18" hammer drill wx18hd. The charger without a battery connected light is green. When I charge a battery for several hours the charge holds for about 5mins.
tbreeze47
  • 3083 Answers
SOURCE: The WORX triimer battery is
Make sure the battery and trimmer's contacts are clean- use a qtip and isopropyl alcohol, or a pencil eraser, or fine emory cloth, if corroded or oxidized. This could be a cracked, loose, or corroded connection anywhere in the wires or power feed, including the switch. If the battery is getting old, it could charge, but not hold enough juice and run down quickly. Measure the battery after it's charged, and then try to start the trimmer, and measure it again. If it's dropped, it could be a bad battery. A motor can short out, but that's the last thing to suspect. Here's what one person said in a review on Amazon.com:
y GrampaSmo "Grampa" (Maryland USA) - See all my reviews
This review is from: WORX Air WG541 18-Volt Cordless Blower/Sweeper (Lawn & Patio) The blower is ok but the battery does not last more than 5-7 minutes. I called Worx and they replaced the battery but it still does not work more than 7 - 10 minutes. Worx said I needed to recondition the battery by draining it totally then recharging (4 times) and to always drain fully before putting back on charger. This did not work. When I asked Worx for my money back they told me they couldn't do that at this time (even though the product is under the 2 yr warranty timeframe).
Bottom line: don't waste your money. Product is POOR.
Not encouraging, but hopefully it's just dirty terminals.
Good luck, and hope this helps.
Posted on Sep 26, 2010
rycgl
  • 1545 Answers
SOURCE: I am having problems with the battery on my worx
You can determine exactly what is going on by using a small handheld voltmeter. They are inexpensive, easy to use and come in very handy. Just test the output of the charger (after noting what the volt-output-rating is) by touching the leads of the meter to the terminals on the charger. If the charger is working at all, this is not a dangerous test. Conversely, test the output of your batteries by touching the leads of the voltmeter to the terminals on them. I suspect the charger is bad because after they overheat, they quit working and some don't last very long. I don't think YOU are doing anything wrong, just maybe the companies that manufacture these 2 electrical products are.
Posted on Oct 14, 2010
SOURCE: The battery on my Worx GT doesn't seem to hold
the first time the Worx GT worked great since then I took it off the charger and it won't go more than five min. without going dead. I'm back using my gas trimmer what's up ith th battery on the Worx Gt
Posted on Nov 07, 2010
  • 130 Answers
SOURCE: battery charger on a Worx
Flashing red light indicates battery is bad. Flashing green light indicates charger is bad.
Posted on Feb 21, 2011
  • 8 Answers
SOURCE: battery won't hold a
I had the same issue with my Worx battery.
Check to see if you are eligible to receive a new battery replacement:
http://www.worxbattery.com/
Posted on Aug 19, 2011
Worx charger
Usually the indicator lights while charging is underway but sometimes the indicator is on whenever the charger is connected regardless of what's happening or supposed to happen. Try charging the battery, ignoring the indicator. Obviously if the battery does not charge, the fault is with the charger
May 11, 2013 | Worx 18V Cordless Hammer Drill Driver with...
How long should a fully charge battery last on WG250E Hedge Trimmer
This is the info i found on WG250 battery . It says up to 50 min below in the features. Hope it helps
Battery
The WORX WG250 hedge trimmer incorporates an 18-volt 1.7 Ah Ni-Cd battery pack. You can use this battery pack with other WORX Ni-CD PowerShare tools. The included charger takes about an hour to restore a dead battery to full charge.
Cordless Hedge Trimmer 18v Worx WG250E jQuery(document).ready(function($) { $("a[rel=product-image-gallery]").fancybox( { 'transitionIn' : 'elastic', 'transitionOut' : 'elastic', 'titlePosition' : 'over', 'titleFormat' : function(title, currentArray, currentIndex, currentOpts) { return 'Image ' + (currentIndex + 1) + ' / ' + currentArray.length + ' ' + title + ''; } }); });
Features
  • Wall mount bracket
  • 3 position adjustable front handle
  • overmould soft grip for user comfort
  • Quick release handle
  • Double insulated
  • Volts: 18
  • Blade length: 510mm
  • Cutting capacity: 14mm
  • Blade action: Dual
  • Run time: Up to 50mins per charge
  • Charge time: Up to 1 hour
  • Machine weight: 3.1Kg
  • Comes with one battery and a charger
Sep 13, 2011 | Worx Wg250 20inch 18volt Cordless Hedge...
Charger light blinks red never goes to solid red which is charging mood Had a friend charge the battery it does charge problem is with the charger not the battery
Worx has had issues with their chargers and their batteries. They don't seem to last as long as the machine does. A simple voltmeter test of the charger and any battery will tell the story. The charger's output rating should be printed on it and the battery also. Touch test leads from voltmeter to the two and check.
Oct 31, 2010 | Worx GT WG150 10 in. 18 Volt Cordless...
The battery on my Worx GT doesn't seem to hold it's charge. I have actually taken it directly off the charger when the light is green and it doesn't have full power. Sometimes it does. The unit is 3...
Jul 16, 2010 | Worx GT WG150 10 in. 18 Volt Cordless...
Worx GT WG150 10 in. 18 Volt Cordless String Trimmer w/ 1 battery Logo
50 people viewed this question
Top Worx Garden Experts
Tim Whalen
john milligan
Jay Finke
Jay Finke
Are you a Worx Garden Expert? Answer questions, earn points and help others
