Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Do you have a vidio i can see how to adj valves
    Sergeant:
  • Craftsman Expert
  • 374 Answers
Posted on Oct 16, 2014
99kawasakiprarie300valveadjustment
MOVE EACH CYLINDER TO TOP DEAD CENTER OF COMPRESSION STROKE ( sorry caps on .) check that timing mark in timing cover hole is in line .remove adj cover per cylinder in alignment and adj valves according to mfg specs. to adj : under adj cover , loosen lock nut on top then loosen adj nut on btm @ top of valves . insert feeler gauge under rocker and adj ,this is tricky to say the least. usually takes several tries to get it right, keep trying the valves must be set right or major expenses can be expected to occur. intake and exhaust settings are different normally at least .005 .be sure to tighten locknut on top before checking if clearance is correct. holding the btm nut while turning the locking nut is the tricky part 4 me anyway. 2 valves per cyl. on most atv eng. adj all valves .start eng and listen to eng w/o reving up. any ticking noise and you get to start over. should be smooth idling and quiet. no popping or backfiring. smooth starting and off w/o run on. should not be performed unless you are familiar with the procedure. contact me or service center near you if not sure on procedure.correct adj. is slightly snug fit . valves making no noise when done .
Jul 12, 2014 | ATVs
Valve adj procedure suzuki j20a
there is none.
its got HLA's
why not post symptoms.???
Jul 11, 2014 | 2000 Suzuki Grand Vitara
What is the valve gap adj. on 1992 toyota landcruiser with a gas, 6 cyl.
Valve gap adj. Set Between valve stem&rocker arm,it set for properly opening & closing of valve it helps for succesful compression iffect
Dec 11, 2012 | 1992 Toyota Land Cruiser
22 hp ohv misses under load comp.ok valve adj.ok spark,fuel,air,ok w.t.h.
really sounds like a carb problem if it only starts acting up under load
Aug 30, 2012 | Briggs & Stratton Briggs Stratton Intek V...
2003 yamaha yz450f valve adj specs
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Master List Dirt Bike Valve Clearance Spec
yamaha yz450f valve clearance specifications
YAMAHA YZ450F Owner Service Manual
OEM parts for Yamaha
Yamaha YZ450F Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 04, 2012 | 2004 Yamaha YZ 450 F
I need to know how to ajust the valves on a1977 Harley Davidson. 1000 iron head
No adj valves .. they have hydraulic lifters ,,now the push rods may be the adj type..but if engine stock push rods not adjustable..
Sep 20, 2011 | Harley Davidson XLH 1000 Sportster...
I have a noise from valve train area which sounds like push rod is sloppy
check to see if you have adj rods ..adj if needed ..but it could be the lifters not pumping up....
Sep 19, 2011 | AMERICAN People S 4T Motorcycles
Why do I need a valve adjustment on my 2001 acura TL
Well believe it or not, your car is one of the few cars that have adj valves. The specs are written on the cam gears, and it is a fairly easy job. If your car hesitates, or rattles, it might be time for the adj. Hope this helps.
Apr 22, 2010 | 2001 Acura 3.2TL
Valve adj.
valve clearances for intake & exhaust are the same 0.10-0.15mm (0.004-0.006inch)
Jun 19, 2009 | 1987 Suzuki GSX-R 750 H
POPPING THROUGH EXAUST
If it didn't pop after the valve adjustment, try adjusting the valves again.
Popping out the exhaust usually indicates a burned exhaust valve. The valve doesn't seat all the way around and air/fuel mixture is getting into the exhaust header on the compression stroke and igniting from header heat. The reason this doesn't happen at higher rpms is the amount of time for the air/fuel to leak it really short.
Dec 08, 2017 | kawasaki Full Suspension Mountain Bike Men
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
