Question about Refrigerators
Age of sears model 106.51212100 refrigerator - Refrigerators
Tip
Kenmore (Sears) model number to real manufacturer decoder ring
This job aid will decode who manufactures the Sears Kenmore appliances. Write down the entire model number and point your web browser this die-rec-shun...
http://www.appliance411.com/parts/sears.shtml
This tool works for all Kenmore products, not just refrigerators.
on Apr 13, 2009 | Kenmore 73503 Stainless Steel Bottom...
Looking for age of my ken more fridge
What year is my model 363.9725813 Ser No. L22340108
The manufacture data is 08/06/1987.
Answer is from Sears Direct chat.
Jan 03, 2014 | Kenmore Refrigerators
What year was model number 253. 54622402 built? Freezer is not getting cold enough is it worth fixing?
can;t help with sears model # for age but do ck the model # plate for the type of coolent like R 12 or R 134 / if its 12 i would replace frig .. the poor cooling on any frig may be caused by dirty coils or fan motor blowing over the coils . clean them and ck that fan is going . ther is also a fan in freezer that may have quit so ck that one also . mm hope this helps .. feeed back pls .. mm
Sep 18, 2011 | Kenmore Side by Side Refrigerator
Find out how old is my kenmore fridge model #596 62822200
You will need your model number and Serial number handy. The first three numbers will tell you who made your machine. (( Sears kenmore Does not make machines, They just put there name on it. ))
Go to this link and go to Who Made my Kenmore.
Im sending you to this link because it is very infomational about the age of kenmor and many other machines.
Jan 14, 2010 | Refrigerators
How do i find out age of my kenmore fridge model # 596 62822200
Your Refrigerator was Made By Amana (( The first three numbers are the true manufacture, Sears and Sears kenmore or kenmore Do not make Machines. )) you will need your serial number to find the Age. go to this link and use the Amana refrigerator link to find your Age.
Compressor comes on but does not cool below 54
Good day,
The compressor is not starting. Either the compressor has failed, or the starting devices mounted on the side of the compressor are bad.
The parts mounted to the side of the compressor, are the overlaod protector, the starting relay, and on some models a start/run capacitor.
These items can be removed from the compressor, and taken to an appliance parts house for testing. You do not have to go to Sears. If the parts check O.K., then the compressor (a major cost item has failed).
P.S. If this machine is under 5 years of age. leave it alone. Call Sears for service. The compressor is under warranty for 5 years.
Jan 01, 2010 | Kenmore 22.0 cu. ft. Side-By-Side...
New kemore compact won't get cold, motor runs ok but won't turn off
If it's new (under 5 years of age) it is under factory warranty, if it's a sealed system failure. Bad compressor, refrigerant leaks, or restrictions in the connecting tubing.
Contact Sears with complete model and serial number.
Nov 08, 2009 | Kenmore Stainless Steel Compact...
Age of Kenmore side by side refrigerator
Brand: Kenmore
Type: side by side refrigerator
Country: USA
Model: 106.58123700
Serial: HRW2754229 This product appears to have been manufactured the week of June 30, 2008
for anything like that next time on any other appliance check out this link by clicking it directly
http://www.appliance411.com/service/date-code.php
Apr 01, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
