Question about Farberware FCP280 Stainless Steel Percolator
Why doesn't percolator run long enough - Farberware FCP280 Stainless Steel Percolator
  • 4 Answers
The thermostat in the base of the pot needs replaced...it is the little round thing pressed against the base of the pot. (You can see it after removing the base of the pot.) Pull off the leads and remove the screw holding it in and get a new one at goodmans.net ($10 including shipping...I just got one from them.)
You should take a picture before removing anything to make sure that you get the leads connected up correctly.
You have a main perk element and a keep warm element in the base of the pot. Plus a thermostat pressed against the bottom to sense temperature. Upon plugging in a cold pot, the thermostat reads zero ohms and applies 120 volts all to the perk element. Then when the thermostat senses a high enough temp, it opens and 120 volts is still applied to the perk heating element, but this time through the keep warm element (about 200 ohms or so). So now the perk element although hot is not hot enough to continue perking, just keeps your already perked coffee warm.
On a cold pot, you should read about 17 ohms looking into the pot...on a warm pot (with the thermostat opened up) you will read in the hundreds of ohms.
Posted on Oct 29, 2014
How to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
Vintage farberware percolator does not stop percolating
There is a thermostat in the bottom of the percolator that is broken. It would normally cut off the percolator heating element after the water reaches a certain temperature. It can be replaced but it takes a little skill. There is a video on eBay.
If you want to just unplug the percolator, time it for 1 minute per cup.
Jan 25, 2014 | Faberware Coffee Makers & Espresso...
I have a 2003 Ford taurus. I keep on losing a lot of the coolant out of the resevoir cap. It percolates, then I lose it. I've replaced the cap twice. The first time it looked like the cap was...
When it is percolating, can you feel if the bottom radiator hose is hot and the top one cool? If so your thermostat could be bad. Are your cooling fans coming on at the right times and last but not least, do you have any water in your oil? That could be a bad head gasket and the percolating would be the exhaust gases bubbling back through the radiator.
Jul 13, 2017 | 2000 Ford Taurus
Why won't our poly perk percolator shut off?
I just bought a Poly Perk percolator from a thrift store. If yours is the same, it's a vintage plastic, electric percolator. I found your question while searching for directions for mine. My percolator does'nt shut off either. It just continues running. I don't know if it has a shut off, but I figure I'll just unplug mine for now since it made really good coffee. If it's supposed to shut off, I suspect we're both stuck with few options. I hope you find your solution though.
Jan 18, 2012 | Regal Coffee Makers & Espresso Machines
My West Bend 3520 percolator does not heat enough to actually percolate. It heats water to about 80 deg and then stops. Power cord looks fine. Any thoughts?
the thermostat isn't holding long enough to get the desired heat any longer,, it needs replacement , the parts are hard to locate, and then you need to have it replaced, so I guess it depends on if you want that done, or just get a new 12 cup one at target for around 40 bucks http://www.target.com/p/West-Bend-12-cup-Coffee-Percolator/-/A-12408458 I tried searching for the part you need, But was unable to locate it
Sep 11, 2011 | Vacuums
Water boils but doesn't percolate
Try cleaning the parte that is in the medel
The part mast have coffee in the center try to clean and see if that helps.
Aug 01, 2011 | Bodum Mocca 1176 Coffee Maker
My new percolator will not perk? Water gets hot but doesnt seem to rise to the top.
I had the same problem, and I figured it out. Read on, to see if this applies to you. This percolator was received as a present years ago, and I'm not sure it ever worked right. First, some info and background. The above comments about the heating element being clean to bare metal, while valid, did not work for me. I also read other posts suggesting the thermostat might be defective, which also did not seem to apply to my situation because the water is always hot enough at the end of the cycle, not boiling, but steaming hot enough for just about anyone. I deduced the problem to be with the actual perking process, not heat or heating element. A percolator should perk before the water is at drinking (HOT) temperature, and the perking action cools the water and prolongs the actual perking process. The problem I found was with the washer at the bottom of the tube, which is supposed to act like a 1-way valve. The washer, from the factory, was apparently too loose with almost a 1/4-inch or play, allowing hot water that would otherwise perk back into the water chamber, effectively making my percolator into a kettle. I used a stainless steel washer and an e-clip to tighten the washer against the holes on the lower umbrella-shaped flange so that there is just enough room to slide a feeler gauge or perhaps a couple of sheets of paper. Now the percolator works great, fantastic actually. Watching the coffee perk at the top in anticipation of a hot cup is entertaining, and with the stainless steel pot I have no worries about phytoestrogens leaching from plastics common in drip coffeemakers. See photo of my hack if it uploaded correctly. Its high res, so you may be able to download and zoom in. Enjoy! new-percolator-will-not-n1see0xg4iab1sfdaqlesvfh-4-1.jpg
Oct 18, 2010 | VillaWare Mini-Perk 5120-05 Coffee Maker
Weak coffee
If it's the thermostat, the water may not be reaching a high enough temperature. I'm not too sure how percolators work, but you could maybe try running another "cycle" to extract more from your ground coffee? Otherwise, try a finer grind to increase the strength of the brew.
Mar 31, 2009 | Coffee Makers & Espresso Machines
Farberware FCP280 Stainless Steel Percolator Logo
139 people viewed this question
Top Farberware Coffee Makers & Espresso Machines Experts
Ed Mac
Kolbrun...
Are you a Farberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
