Question about Makita 1,100 Watt 2.5 Hp Portable Power Generator #G1100
What oil capacity for a G1100 Makita generator
4 Suggested Answers
smartr10U
  • 1305 Answers
SOURCE: Makita G11oo portable generator. starts on choke. cuts off run
Just noticed your question... If you still need a little help:
1. If the gas is from last year, drain the tank and the carb bowl and replace gas with new. Visually inspect the inside of the tank ..be sure there's no sediment that needs to be cleaned out.
2. remove air cleaner and make sure it's not plugged or dirty
3. plug the spark plug and clean with spray carb cleaner.
4. At end of season, mix some gas stablizer in with the fuel to keep it from going bad while in storage.
Let me know how it goes..
k
Posted on May 31, 2009
mkh5094
  • 145 Answers
SOURCE: TYPE OF OIL USED FOR A MAKITA GENERATOR G1100
10W-30 is what the factory specs call for.
Posted on Jul 21, 2010
mc1bean
  • 3053 Answers
SOURCE: what tipe of oil makita
Great generator, i use 15/40 Quaker State it seems to work well for my uses, i have same one, but is 2000. check your manual if your really concerned, the whole thing, is keep oil fuel, and changed often. Hope this helps mike
Posted on Jun 13, 2011
What does a diode stack assmelly do on my
makita g5501r parts Power Generators Questions & Answers
www.fixya.com > Forum > Tags > makita g5501r parts
Power Generators makita g5501r parts questions and answers. ... I own a makita 6100generator and it is only putting out about 105 volts ac and about 208 volts .
Nov 18, 2015 | Makita Electrical Supplies
Leaking gas overflow
The float is probably stuck, or there is debris in the needle valve seat. may be time to rebuild the carbureator.
Jul 18, 2014 | Makita 1,100 Watt 2.5 Hp Portable Power...
What tipe of oil makita generator g1100 takes
Jun 13, 2011 | Makita G1100 1100W Generator
Oil capacity and weight of oil
If it comes with a Briggs & Stratton 3.5 HP series 93400 engine, then the oil capacity is 20 fl oz (0.59 L). Hope this helps!
Sep 20, 2009 | Coleman Powermate Powermate 5000W...
What will a 2.5 hp engine run please?
It's a 1100 watt gen, so you have 1100 watts available to use. All electriccal equipment is rated it volts and watts. Just do the math...
Jul 18, 2009 | Makita 1,100 Watt 2.5 Hp Portable Power...
k
May 21, 2009 | Makita 1,100 Watt 2.5 Hp Portable Power...
Makita Generator suddenly stops has gas
Hi
Hi See if the gas tank cap vent is clogged,remove the cap and check the gasket in it.Check the flyweel key(not to be sheared) and the condenser( not to be defective).The ignition points(not to be burned).Check the oil in the crankcase(pay attention to the low-oil-level shutoff sistem (if there is one).Check the fuel lines and filter.Check the muffler(not to be clogged).Check the plug wires and make sure is securely attached at the sparkplug.Check the cable and linkage.
best regards savumihai71
Dec 15, 2008 | Makita 9 Hp 4,300 Watt Portable Generator...
Makita 1,100 Watt 2.5 Hp Portable Power Generator #G1100 Logo
16 people viewed this question
Top Makita Electrical Supplies Experts
Craig Butler
Craig Butler
obsteiner
Tom Chichester
Are you a Makita Electrical Supply Expert? Answer questions, earn points and help others
