Question about Canon EOS 7D Digital Camera
What is the cost of replacing a broken shutter on a 7D?
Konica minolta maxxum 7d support
This is a common problem with the 7D. The shutter curtain will stick after several years of service. Put the camera in clean mode to get the curtain to lift, or send it to Sony to replace it. It was a design flaw by Minolta.
Nov 10, 2013 | Konica Minolta Maxxum 7D / Dynax 7D...
How can I find out the shutter count on a 7D?
In the camera setup page2 set "File # memrory" to ON
From now the pictures are recorded on the CF card with the shutter counter number (for example Pict8194.jpg or Pict8194.mrw)
You can read this when you look at the pictures with the play button and press the dial UP, the third line from the bottom shows the directory and the counter number (for example 100KM023-8194,
Feb 09, 2011 | Konica Minolta Maxxum 7D / Dynax 7D...
The shutter does not operate.When the battery is inserted, all it does is adjusts the focus and does not click when you press the shutter. I'll appreciate your advice.Thanks
One of the most common problem is the antishake system.
When switched on, the carema shakes and makes sound for a second or two.
When the antishake is switched on (slide switch right of the ISO button) the 5 LED's of the antishake scale right in the view finder are flickering continuously.
When the antishake is broken, the camera doesn't fire even when the antishake is switched off.
Mar 10, 2010 | Konica Minolta Maxxum 7D / Dynax 7D...
Shuter dosnot work
The shutter release problem is very common in the 7d. The carbon rods in the stabilizing servo fail. I have had quotes of just over $400 from non OEM. I recommend sending it to Sony. Good luck
Feb 10, 2010 | Konica Minolta Maxxum 7D / Dynax 7D...
My minolta maxxum 7d won't take a picture....The shutter will push down but no picture will be taken. I tried it later in the day then it worked. Now today I tried, it worked this morning and then not...
Precision Camera picked up the responsibility for fixing the 7D and 5D Konica-Minolta cameras when Sony bought out K-M. I contacted them when my 7D wasn't functioning, and sent them my camera. Fortunately, on of the problems was "First Frame Black". Precision completely refurbished my camera and returned it to me in better than new condition. Sony picked up the full cost for the total refurbishing; all I paid was the shipping cost to Precision. I might add that my 7D was not in warranty. The URL for Precision Camera is:
http://www.precision-camera.com/ . Give it a shot.
Oct 27, 2009 | Konica Minolta Maxxum 7D / Dynax 7D...
Camera shuts off after one shot
Set the camera to clean ccd mode and carefully remove the lens. If you can't see the ccd but only the shutter then the shutter is sticking. I have this problem when not using the camera regularly. My solution to free the shutter was just to set the camera to long exposure and just keep restarting the camera and taking a photo until the shutter moves. This problem happened from the very first time I had the camera run low on batteries at a few months old but at the time I never checked the shutter and the camera just restarted once and it worked.
Sep 05, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
BLANK (BLACK) PICTURES
Yes this is a common problem. Set the camera to take a long exposure shot (5 seconds) and with the lens off take a photo. Can you see the ccd or just the shutter (black)? If its just the shutter the shutter is jammed. It's basically a question of persisting with rebooting the camera and taking shots until the shutter frees itself.
Jul 23, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Maxxum 7D Not Taking Pictures
your having a problem with the antishake
Apr 19, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
LCD Display
I was cleaning my CCD and damaged the shutter. Same problem. Click to take a picture and the camera locks up and powers off. Turn the camera back on and the shutter releases and the camera resets and powers on. $281 service call later and Precision fixed it quickly. Replaced the shutter. They warranty their work for 6 months. Priced way too high, but nobody would touch it. As soon as I told other repair services how I messed it up, they turned me down. I had to much money invested in the camera to toss it in the closet.
Nov 24, 2007 | Konica Minolta Maxxum 7D / Dynax 7D...
Canon EOS 7D Digital Camera Logo
29 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
