Question about Dynex 4-Port USB 2.0 Hub
4 port USB hub not working...
After cleaning up the desk, my 4 Port USB hub has stopped working, it will work up to the point that windows starts to load and then it will turn off.
  • 1,272 Answers
Try connecting the hub to another USB port. You may even connect this same device to another computer and check if that works. This will help isolate the issue better.
Posted on Jun 23, 2009
Why my siyoteam 4 port usb 2.0 high speed hub not working in windows 8 hp laptop. i plug the port into the laptop but it cannot been seen in my pc, is there any thing can i do inorder this usb hub to work...
Perhaps the laptop port is designed for a usb 3.0 insert instead of a usb 2.0? Also try using compressed air to clean both connections. The hub male end and the laptop female end.
Oct 31, 2013 | Universal Genuine SIYOTEAM 4-Port USB 2.0...
My dell latitude d600 usb ports stopped working how can i get it fixed. thans
If ALL the usb ports have stopped working, this is a problem with the USB controller. The short answer is that you cannot easily repair this. In all probability, the controller, or a circuit trace to it has blown or shorted. You would need to get another motherboard.
If one is still working, then you can get a PCIMCIA card to usb port that will give you 2-4 extra ports, but this will only work if at east one of your existing usb ports is still functioning
Aug 16, 2011 | Dell Latitude D610 Notebook
Targus Travel USB 2.0 4-port Hub
sometimes usb hard drives will not work through a usb hub.
if the drive works connected to the laptop but not the hub then that's how you'll have to use it.
it's also possible the laptop cannot power both the hub AND the drive, in whaich case you'll need a powered hub (one you plug in to the mains).
Sep 21, 2009 | Targus PAUH217U 4-Port USB Hub
I purchased a 4 port usb 2.0 hub can't seem to work
Have you install the driver first before connecting it? Check out the Device manager entries if showing any yellow mark?
Goto start --> Run --> type in there --> devmgmt.msc this will open up the Device manager.
Check it and let me know. Have a nice day
Mar 17, 2009 | Cable Showcase 4-Port Mini USB 2.0 Hub, AC...
1 USB Port Failure
Hi Guys
Unfortunately after looking at the computer installation details i was at fault, although i have had
the computer for well over 2 years and this is the first time it has happened.
My Dell Dimension 5150 has 7 USB ports 5 at the back and 2 in the front and it appears that i have
connected the keyboard and mouse to the wrong ports.
There are two ports at the bottom allocated for the keyboard and mouse and for some reason i had
them in the top three ports hence my problem but still not sure why it happened.
Anyway my Dell Dimension 5150 is now running OK and no further help is needed.
Many Thanks.
Nov 03, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Installing USB Hub
After installing the USB controller card into a PCI slot inside your computer, connect the 4 port hub to it with the supplied cable. (at the back of the computer)
Do not connect the DVD Recorder to the old usb ports. They will still work, but obviously not 2.0.
Connecting the power supply for the hub is optional, but usually a good idea.
If your computer still doesn't recognize the hub, make sure you have all of the latest windows updates and try running Add New Hardware in control panel. Also, just unplugging the hub and plugging it back in will sometimes work. Use a different port on the controller card if necessary.
As a last resort, you may need to disable the onboard usb controller through your system bios.
Good Luck
Sep 11, 2008 | CyberPower CPH420P 4-Port USB Hub
I-rocks IR-4300 4-Port USB Hub doesnt work
You shouldn't need a driver for it, Windows has bundled native drivers that will be enough to make it work.
Does anything else work in the port you plug the hub into?
Jul 11, 2008 | i-rocks IR-4300 4-Port USB Hub
Targus Travel USB 2.0 4-Port Hub with Notebook Light
I'm sorry to tell you your hub cannot be fixed. I have one just like it and have taken these things apart and repaired simple factory errors as loose wires and the such.
You should get yourself another Targus brand USB hub. They are good and quite reliable
Regards,
Worldvet.
Jun 08, 2008 | Targus 4-PORT TRAVEL USB 2.0 HUB...
USB ports no longer working
After all done,
Did you think of replacing motherboard?
Feb 17, 2008 | Computers & Internet
Dynex 4-Port USB 2.0 Hub Logo
1,509 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Mike
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
