Question about Refrigerators
GE refrigerator side-by-side not cooling.
About three weeks ago My refrigerator stopped cooling while the freezer worked well. Thanks to this DB I found my evaporator coils were iced up so I thawed them and clean my condenser coils. Everything seemed to work well. Now, three weeks later neither my refrigerator nor freezer will cool. I have checked the evaporator - there is no ice on the evaporator coils and they are not cooling. I have check both freezer thermisters - At 32 degrees they measure 16,300 ohms respectfully. I don't know what to check next.
SOURCE: refrigerator 52 degrees
Hi Mike,
I am having the same problem with a Hotpoint side by side. (Model # hss22ifmd ww ) Could you tell me the more detailed info mentioned above. Thank you so much.
chris
Posted on Jan 02, 2008
  • 143 Answers
SOURCE: Maytag Model MZD2766GEW iced coils
This sounds like a defrosting problem. There is a defrost timer, a heater element, and a therm-o- disk thing that shuts the heater off when the frost is melted. These are the things to check, but it's usually the heater that is burnt out.
Posted on Jul 23, 2008
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
  • 54 Answers
SOURCE: My GE Profile PSS26MSTSS is not keeping food cold.
You need a new defrost heater
Posted on Jan 04, 2009
  • 198 Answers
SOURCE: freezer working, not making ice; refrigerator not cooling
Look for excessive frost build up in the freezer, there may be a problem with the defrost cycle.
Posted on Jan 09, 2009
My GE side-by-side is not cooling.
The electronic control board is probably your culprit. These control boards control the compressor, fans and defrost. Look for any burned spots on the printed circuit bout it could be just bad.
May 11, 2014 | GE GSS25SGPSS Side by Side Refrigerator
My refrigerator stopped cooling and my freezer stopped freezing but the freezer is still cooling
Same thing with our GE Eterna Series - off and on for the last two weeks. Took back panel off, looked around, vacuumed dust build up off of the fan blades, etc.; everything worked fine for five good days. Then frig went out stopped cooling. Off and on for the last week. Unplugging it works for a day then back to not freezing and or colling.
Jul 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator seem to not cool to the proper
your problem is in hte freezer area open the panel in your freezer you might need a new heat element or a new thermostat unit... not so bad to do or check...
arik from 911.servicetoday.com
Nov 06, 2009 | Kenmore 53092 / 53094 Side by Side...
Freezer not cooling/making ice.
At this moment I think that you need to unplug the refrigerator and remove the ice maker to stop the leaking. Any extra water inside the freezer will make it harder for the defrost to remove the moisture. While the ice maker is out I want you to look to see if water is still leaking out the fill tube that feeds the ice maker tray. If it is then we found the reason. If not then we need to check some of the parts on the ice maker. Let me know what you find, Thanks, Sea Breeze
May 20, 2009 | GE PSS26PSS Stainless Steel Side by Side...
GE side by side refrigerator has stopped working...
sound to me that the unit may be stuck in defrost. look for the time clock and or if it is a newer unit check your condenser coil it may be dirty. the unit may also have a leak on the refrigeration side of it.
Dec 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Jul 17, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Bottom freezer not working
Hi, sorry I do not have any advice to offer. We have the same model. Three weeks ago the red light came on and freezer stopped working. Last week the fridge packed up. We may have been unlucky but I thought it might be worth mentioning incase they were related and your fridge gave up as well.
Jul 06, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
GE side by side refridgerator
you need to check the defrost heater with a omes meter,ge sxs are very bad about heater burnout and most must be replaced with a heavy duty one,let me know,thanks-mike
Jun 23, 2008 | Refrigerators
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
