Hp laser jet 1020 printed blank. toner, scanner ok
My printer hp laser jet 1020 printed blank. toner ok. scanner ok.
    Problem Solver:
  • 9 Answers
Laser jet printer oprated with positive or negative charge by charging ruler so please chek it.
Posted on Jun 23, 2009
How can fix this error. i seen this "the hp laser jet 1018 has the front cover door open or the toner cartridge is missing"
Hello !!
For tha particular error you are facing, here is the reason. These printers have a switch that triggers an interrupt when the toner door is closed. Usually there is an arm on the door that pushes the switch. It is quite sensitive and delicate. Then sometimes there is a tab on the printer's toner and if that breaks off then that error will be generated.
But in your case as you have not removed or inserted the toner, I think option 1 is applicable to you.
Now, if this printer is in warranty you should send it to HP for Free repair/replacement.
and chek BLOW links too for paper jam and cleaning
Paper jam Message Displays for HP LaserJet 1018 1018s 1020 and 1020 Plus... Cleaning the Printer
Dec 23, 2014 | HP LaserJet 1018 Laser Printer -...
Why my laser jet hp 3030 print blank pages? even demo page!
aw free internet help! blank pages..laser scanner control board has died. if you have another, pop it in, do a test.
or the toner is defective. make sure all connection on the sides are clean.
Jul 24, 2014 | HP LaserJet 3030 All-In-One Printer
Hp 1020 laser printer output is blank
Have you replaced the cartridge? It is probably causing the issue you have. Toner will compact if it sits for long periods of time.
Aug 04, 2012 | HP LaserJet 1020 Printer
Blank printing sharing printer hp laserjet 1020
Is Local system print ok?If you are not OK.Then change your toner cartridge.or Sharing not properly.
Dec 09, 2009 | HP LaserJet 1020 Printer
I have HP Laser Jet 1020 When I print letters
Most cases on that machine it's the transfer roller that does that at 75mm, but could also be drum cartridge or fuser. Use a flashlight and inspect the fuser, shouldn't be toner or image on fuser rollers, If you unplug the machine when the print is in the middle, you can tell if it's before or after the fuser, and after the drum.
Nov 24, 2009 | HP LaserJet 1020 Printer
HP Laser Jet 4250/4350 series says its ready then it prints blank page and sends a message 51.20
Try a replacement toner cartridge first.If this fails, then i suspect it's a laser scanner fault. The error denotes beam detect error which is more than likely a laser scanner fault
Oct 12, 2009 | HP Office Equipment & Supplies
HP LASER JET 1020 PRINTER...print with nothing word
take the toner out and check to see that it is full and ready to use
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | HP LaserJet 1012 Printer
Getting vertical line on the right side of the paper
Sounds like a defective toner cartridge. Try replacing it
Apr 23, 2009 | HP LaserJet 1020 Printer
Why will the HP Laser Jet 1020 not print?
this is a usual problem with the early models of printers. if you go onto control panel and then printers for the properties then print test page. if this prints fine then you will have to use the add/remove programmes to remove printer software. then delete the printer and install again but not from disc as windows has a package which will do it for you. leave disc in drawer and dont run. just search for the drive whilst installing printer. if this doesnt solve your problem then use the software which you will have to install again. if this doesnt occur then take cartridges out and check if they are correct ones or compatibles as hp not too compatible friendly due to counters.
Feb 25, 2009 | HP LaserJet 1020 Printer
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
257 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
