Question about Konica Minolta magicolor 1690MF All-In-One Laser Printer
Minolta 1690mf printer not printing from computer
    Habit-Forming:
    New Friend:
  • 43 Answers
Look at the port
Posted on Sep 07, 2015
SmartAviator
  • 449 Answers
SOURCE: Manual for koniccca minolta magicolor 1690mf
Try searching yoyr required manual at the manufecturer's website or http://www.devicemanuals.com . They have a large databse of manuals. (ehteshamhusain@gmail.com)
Posted on Jul 23, 2009
SOURCE: how do i fix the error message MACHINE TROUBLE
1. Main switch is tuned ON.
2. Press the following keys in this order
2 -> 6 -> 2 -> 7 ->3
3. Main switch is tuned OFF/ON
Posted on May 11, 2010
SOURCE: I have konica minolta magicolor
Remove the Yellow toner Cartridge see if the printer will print without the cartridge, you can cancel the warning and there should be an option to check or uncheck saying do not show this warning again/in the future.
Posted on Sep 06, 2011
bronk50
  • 27725 Answers
SOURCE: i bought a konica minolta magicolor 1690mf,
Since several computers or laptops will access the printer, it is recommended to connect the wireless printer to the main computer through the USB port.
To begin the installation process on Windows XP, access the network setting in the Control Panel, and activate the file and printer sharing option in the LAN setting.
This will allow the operating system to recognize the availability of a wireless printer.
Now, click the Start button, go to Devices and Printers, select Add a Printer option.
Click the second option- Add a network, wireless or Bluetooth printer.
The computer will search for available printer and reflect it on the screen.
Click Finish; and the printer is ready to begin the printing process.
if you have any problems with your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or
select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Posted on Sep 19, 2011
  • 1739 Answers
SOURCE: please i want to know if konica minolta magicolor
The Konica Magicolor 1690MF Printer/Copier/Scanner is connected with an Ethernet Cable or USB Cable. It is not equipped to operate as a wirleless printer. It has a 10Base-T/100Base-TX Ethernet interface port and a USB Revision 2.0 High-Speed compliant port.
To do two-sided printing you must have the duplex (double-sided) option installed. This also requires either Tray 2 or the Attachment to be installed underneath your machine. Tray 2 is the optional lower feeder unit which increases capcity of your machine to 500 pages. The Attachment comes with the Duplex Unit.
Only Letter and A4 plain paper (16-20 lb bond) can be autoduplexed. With the duplex accessory installed you can do duplex or double-sided printing automatically.
From within Printer Preferences select Two-side Printing > Automatic. Shoud have choices of Off, Manual or Automatic. Within the Layout Tab for your work you may also be able to specify duplex (double-sided).
Should you have continued difficulty, please reply and advi e if the duplex option is installed and with which software and operating sysytem you are using.
Thank you for using FixYa!
Posted on Sep 20, 2011
Ow do i fix the error message MACHINE TROUBLE SERVICE CALL (0310) on my konica...
replace the print head. That's the part that houses the LASER. try this site for the part
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
if not try local Konica Minolta dealer
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 28, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Why does my Konica Minolta 1690MF have a fuser jam error whenever I print in color?
Everything you checked sound good. Might be printer software problem, and needs to be re-flashed. Software only available from secure web site that a technician would have, see what it cost if to much buy a new one with extra bells and whistles !
Jun 18, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Konica Minolta 1690MF causing Fuser Paper Jam error when printing color. Does NOT happen when printing black and white. (Paper is genuinely stuck entering the fuser). Why is the problem happening for...
I was wondering if the original poster of this problem found a solution. My printer does the EXACT same thing. B & W printing is perfect. Any color print jams in the fuser. The printer feeds the paper too far (from thin copy paper to cardstock) so that the top of the page is cut off. Konica sent me a new fuser but that did not solve the problem. Again, this only happens when printing any page that has color on it (even a document with only one letter in color). B&W printing is unaffected.
Aug 27, 2013 | Konica Minolta magicolor 1690MF All-In-One...
Change ymck toner
The toner cartridge has a chip that calculates the estimated usage of the toner and once it reaches it's capacity (per estimation), it will not print. The only thing you can do is to buy a new cartridge or buy refill toner that comes with a reset chip.
Aug 30, 2012 | Konica Minolta magicolor 1690MF All-In-One...
After changing toners (all 4) my Konica Minolta 1690MF screen says Machine trouble Service call (3C10). Anyone knows what is that mean. On the computer says everything is working fine - your device is...
I have 1690mf and changed cartridges, the 3c10 call engineer appears after printing, paper jammed. Had call out from service engineer, afraid he's at a loss too, says it is a security issue but no instructions on how to repair, waiting now to hear from Konica theselves as to what is the answer, I can still print, just have to take the paper out and switch on an off when it stops, annoying though
Mar 25, 2012 | Konica Minolta magicolor 1690MF All-In-One...
Our Konica Minolta 1690MF only prints the centre of the page and not the rest of it, please help?
you may have to replcae the fuser . typically a fuser will have to replaced once every 4 toner replacements .
have you tried the support site at konica-minolta ?
http://konicaminolta.ca/business/products/office/printer/magicolor/magicolor1680MF/index.html
Jan 03, 2012 | Konica Minolta magicolor 1690MF All-In-One...
Cannot print from my computer
please send me any error code . I shall help you
Aug 13, 2009 | Konica Minolta magicolor 1690MF All-In-One...
Konica Minolta magicolor 1690MF All-In-One Laser Printer Logo
35 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
