Question about Yahoo Messenger
81003004 error connection yahoo messenger - Yahoo Messenger
    Problem Solver:
  • 10 Answers
You can try this:
Goto Connection Prefrences and use a http proxy
Click on Messenger
Select Preferences
Under Category, choose "Connection"
Then, click on the "HTTP proxy" radio button.
Note: You might want to check the internet connection type as well. If you are using Broadband (DSL/Cable), then change it to Broadband (DSL/Cable).
Posted on Jun 24, 2009
5 Suggested Answers
SOURCE: login error 81003004 from Yahoo Messenger
as far as wat i did to my YM.
i simply checked the connection preferences and turned
"Connect via a proxy server."
then select
"HTTP proxy"
after that take a look at your internet connection dropdown list..
some mistakes are seen here.. instead of having the "broadband" connection selected the "dial-up" connection was chosen by YM itself..
hope that helps ya ^^
Posted on Jan 07, 2009
SOURCE: Error 81003004
Go to this web page link and follow the directions
http://www.error-repair-tools.com/ppc/error.php?t=81003004&gclid=CJDm_aKP4pkCFQw9GgodVFiLVw
Posted on Apr 08, 2009
  • 79 Answers
SOURCE: I've problem to sign in on my messenger and see error 81003004 ?
There have some similar problems when you try to sign your yahoo messenger, you might be have 3 options:-
1. Go to Messenger>Connection Preferences> then, you choose either connection directly to the internet or connect via a proxy server, and then choose type of internet connection>OK>Sign in again... let's try this, may be you can solve this problem. OR
2. Maybe, i think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to use yahoo messenger,check it out, may be it blocked your yahoo messenger. OR
3. Open your Internet Explorer>Go to File>Then you 'uncheck Work Offline, make sure your Interent connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger.
Try to find out these! Good Luck!
Posted on Jun 01, 2009
  • 79 Answers
SOURCE: Login error 81003004 from Yahoo Messenger
Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003005” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version.Hope it was helpful!
Posted on Jun 08, 2009
It has already solved. Refer to :-
http://www.fixya.com/support/t1385966-login_error_81003004_from_yahoo
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 19, 2009 | Yahoo Messenger
Error no.81003004, i'm unable to access my ym, plz help asap
It is some update problem. Were firewall settings blocked ym from opening and connecting. Try this methods....
Read this link
http://www.fixya.com/support/t2536484-81003004
Aug 23, 2009 | Yahoo Messenger
Yahoo error 81003004
sometime yahoo has a glitch or two from time to time
Jul 31, 2009 | Yahoo Messenger
Error 81003004..on yahoo messenger when i try to log in
Hiya,
I'm not usually one to post links to other sites but here is a page that may be helpful.
Yahoo connection error: 81003004
I hope that helps.
Mike
Jul 21, 2009 | Yahoo Messenger
When I try to login to yahoo messenger I get error 81003004
hi,
Follow these methods:-
First method:
1. go to messenger menu
2. select connection preference/ preference
3. the tab will automatic select connection preference, if it doesn’t, select it manual.
4. change your internet conection type, for my problem i choose broadband(DSL/Cable).
Second Method
For me, it was because I had set a localhost (127.0.0.1) proxy in Internet Explorer for anti-filtering purposes, thru which Y! Messenger was trying to connect. So I had to remove it to get it done.
just go to:
Control Panel > Internet Options > Connections (tab) > Lan Settings (button)
then uncheck the Proxy server checkbox.
Thanks!
Jul 17, 2009 | Yahoo Messenger
Whenever I tried to login in the Yahoo Messenger, an error appears 81003004
error 81003004 is a connection problem,
Connection Problems;
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.check connect directly to internet then click ok
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
Jul 10, 2009 | Yahoo Messenger
Entered a connection error 81003004
click the "messenger" icon and then connection preference. Next, click the "connect directly to the internet even though it is already highlighted and then click apply and then ok. I hope this would help your problem
Jun 30, 2009 | Yahoo Messenger
Change your messenger connection settings. I had to check "Connect via a proxy server " in order to sing in.
Goto Connection  Prefrences and use a http proxy.
thank you
Jun 02, 2009 | Yahoo Messenger
Are you behind a firewall (like one in schools) or using proxy??
If so, see any options are available to change the connection settings in yahoo messenger before connecting.
Yahoo Messenger Logo
525 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
Sunday Ojelabi
Sunday Ojelabi
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
