Question about Elite Manual Series Pulldown Projection Screen Projector Screen
ELITE 1256277165 HALF THE SCREEN WENT BLACK OTHER HALF STILL SHOWS PICTURE
Jvc pd-z42dv4 screen goes black after approx half and hour. Can this be repaired?
Usually a few electrolytic capacitors on the power supply board are swollen or burst.
Dec 17, 2013 | JVC PD-42V475 42 in. HD-Ready Plasma...
WHITE PICTURE
my TV has a half black & half white screen & half of the TV is showing the picture including the normal sound,what can I Do,?
Dec 11, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
Samsung ln46b500p3f shows half screen
you sure got original t-con board for replace? part#37704-cog from ebay have. if no you try again . good luck!
Sep 01, 2012 | Samsung Televison & Video
Half a screen on my sharp aqous
There's a circuit board under a metal cover that needs to be replaced. This board conrtols the picture.
Aug 28, 2012 | Sharp 60" Aquos LED Smart TV - LC60LE640U
Only TOP half of picture shows, rest is black???
No,problems u discribing the LCD screen panel some how it shorted and dead.Replacing the LCD screen panel is not an option,because LCD screen panel are 90% of the tv,so replacing it.LCD screen panel will cost the same as a new tv,because LCD screen panel are limited produced by the tv corporations.It time to buy a new tv.
Jul 31, 2010 | Toshiba 32AV502R LCD TV
Only half of my screen shows a picture, the other half is black. It is not a split screen, half of the picture is missing
You have a problem with the vertical IC. Or someone typed into the software and hit a service blank option..Cances are better that you have to resolder the vertical IC. This is a projection TV...correct?
Feb 14, 2010 | Televison & Video
Screen was going red on the top half of the screen, then..
The Y buffers were going bad, sounds like they went , you should get the Y upper and Y lower also the Y main. be aware the screen may be bad but tou won't know till you try the Y boards,
Jul 23, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Half a picture in black
Witch part of the screen you loose?if is the bottom or the top it could be a problem in the vertical IC circuit if is the left side or the right side is a problem on the horizontal deflection circuit(very rare),try taping on the set when it does it and see if the pix reacts ,if it does one way or the other you have loose conections and some resoldering need to be done.If you are familiar with tv circuitry you will have no problem.If you are not be safe and call for help.
Sep 19, 2006 | Mitsubishi (WB2000)
Elite Manual Series Pulldown Projection Screen Projector Screen Logo
32 people viewed this question
Top Elite Televison & Video Experts
Electro Med Services...
Are you an Elite Televison and Video Expert? Answer questions, earn points and help others
