Question about Philips HTS3450 System
Philips HTS3450, sound cutting on and off during DVD playback?
    President:
  • Philips Master
  • 1,114 Answers
If the Video portion of the DVD is running smoothly and the audio is cutting out, you've got an internal problem. You can try running a Laser Lens cleaner thru it, you can get them at just about any retail store, get one that uses fluid, 15-20. Good maintanance habit, run it thru a couple times then try a DVD. If it still has an issue, it's more cost effective to replace it than repair it, a repair would run 100-150 on average. Hope this helps
Posted on Jun 23, 2009
Hi my philips hometheater HTS3450 subwoofer power supply is blown off and the philips guys are giving estimate of 100$. my question is if i dont want to use the subwoofer and the speakers but only connect...
yes.modern TVs have good speakers,and the bravia has a good set,with adjustable sound fields,plus a decent amp in them.just use good cables,and use component video cables,or HDMI if yr DVD has it.most have 1080 video resolution nowadays
Jul 01, 2010 | Philips HTS3450 System
HTS3450/37 DVD player won't spin up to speed.
That is a common symptom of a depected Ribbon connector,you better replace it with identical rating in order to works normal again..
Hope it may helps you;;
Jun 08, 2009 | Philips HTS3450 System
Speakers
Did you read the manual or just started to try and connect everything?
what do you mean by HT slots? I hope not the slots on teh back of the device itself....
Just check here,1 cable from the device to the subwoofer, the speakers should be connected to teh subwoofer: http://www.p4c.philips.com/cgi-bin/dcbint/faqview?scy=US&subrequest=1&mid=Link_FAQs&view=aa12_view_full.html&desc=Philips+DVD+Home+Theater+System+HTS3450+DivX+Ultra&session=20090417124015_94.209.249.65&list=aa12_list_partial.html&slg=AEN&refnr=0006801&refdisplay=AVS_HTS_031&dct=QAC&ctn=HTS3450/37
Apr 17, 2009 | Philips HTS3450 System
I own an hts3450 system, dvd player part is destroyed.
You can check on ebay if maybe somebody else has damaged set. they seem to be sold a lot there. Otherwise contact philips vendor
Feb 10, 2009 | Philips HTS3450 System
HTS3450 from Phillips, have video but no audio
I have been quite involved with a sound problem in my HTS3450 (search for the topic "sound in only 3 channels"), and I learned that when you are in the setup menu the speaker volume will be greyed out if there is a disc in the tray...remove the disc, wait for the "disc loading" dialogue to switch to "no disc", the try accessing the setup menu again. Other than that I have no advise if you once had proper function after moving the system. Check out my experiences with the cable connecting the sub to the DVD/receiver in my postings. Good luck. Steve
Jan 03, 2009 | Philips HTS3450 System
Philips hts3450 have video but no sound.
It seems your device is thinking it has no speakers connected, reconnect teh cable between the device and the subwoofer and make sure it is connected properly.Als chekc all speakercables if they are connected properly and correct (+ on + and - on -).
Installing help
check on www.philips.com and search for HTS3450, all setup details are available there.
Jan 02, 2009 | Philips HTS3450 System
PHILIPS HTS3450 DVD HOME THEATRE SYSTEM NO SOUND
quiero saber como puedo ecualizar el sonido con el control manualmente
Aug 11, 2008 | Audio Players & Recorders
Philips HTS3450 sound problem
As I found somewhere on the internet; there are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #: 272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. Make sure you match the polarity properly when replacing. Your unit will be as good as new and will proibably last forever now.
Jun 09, 2008 | Philips HTS3450 System
Philips HTS3450 System Logo
433 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
