Question about Dell UltraSharp 1907FP 19" LCD Monitor
Dell 1907FP power button stuck - Dell UltraSharp 1907FP 19" LCD Monitor
  • 46 Answers
SOURCE: Opening case of Dell 1907FP to resolve stuck power button
Go here for an instrucional video on opening the cases on DELL monitors.
http://www.lcdrepair.us/Installation.html
Posted on Jun 21, 2008
SOURCE: Removing front bezel of Dell 1907FP monitor to repair stuck power button
ThndrChld's suggestions are great but way too complicated. all you need is a flat head screwdriver. the front bezel/frame/whateveryoucallit can be removed without taking the backside off at all.
the reason the power button gets "stuck" is because it is set off centered from the sensor on the chip underneath it and it relies on a little protruding arm to press down on the sensor...this arm has broken off. button is not really "stuck." its a stupid design flaw by dell or whoever they contracted to make the monitor.
take the screwdriver and just stick it into the seams along the side of the front frame (black frame) and wrench side to side, twist your wrist, etc, to open. you will hear creaking and cracking but thats ok and doesnt damage the monitor at all (though you may create scratches and dents in your casing), its just the clips and snap ins coming loose.
here is a shot of it opened. the chip is held in by 3 very small screws. there is nothing you can do about the power button being broken.
(see this pic shows only front frame is pried open, nothing else) 1086a3b.jpg
the way i circumvented this broken power button is to drill a hole directly through the bezel/frame to the chip itself. i turn on my monitor now with a toothpick (i dont suggest using a paper clip as i first did in this shot, it will scratch up the metal on the chip). you can see where the paper clip is inserted and shows that the sensor on the chip is offset from the power button.
do this or take it into a shop and pay money =). who cares about a nasty looking front bezel, at least my monitor still works.
Posted on Apr 07, 2009
  • 81 Answers
SOURCE: Power Button Broken?
Yes, I think your right, if it is under warranty send it back to Dell for repair, I had the same issue about a year ago.
Posted on May 20, 2009
  • 30 Answers
SOURCE: Power button stuck on Dell 1907FP
Hey People! You Dont Need To Do Any Of This! Just Take Off The Power Button " Via A Small Screw You Insert In The Side Of The Power Button, then You Lift It Up And Take Off The Power Button" Then You Just Take The Edge Of A Tack Or Very Small Obect, insert it in the side, push down and it works! on and off like normal, and nothing complicated!
Posted on Jun 11, 2009
  • 5 Answers
SOURCE: DELL 1907FP MONITOR
There were no screws on the back of my monitor so that was not an option for me. I figured I didn't have much to lose, so I took a very thin and small screw driver and pried the on-off button right out of its socket, which does break it. To the left, inside the hole,you can see where a tab on the button pressed against a small circular inner button. I pressed that with the screwdriver and the monitor turned right on. I replaced the button for the sake of cosmetics and will never touch it again. If I leave the monitor for any extendd period of time I will simply unplug it.
Posted on Sep 12, 2009
Won't turn on
is it connected to the power ? am pritty sure it is it could be the power cord or the power button broken ? worse case the screen.
Nov 09, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
The power button to the my DELL LCD monitor is stuck. It won't "click" when you push it like the 4 other buttons on the bottom of the monitor. I think it may be stuck in...Is there an easy way to fix...
This is very common problem with this series, the plastic actuator is broken off, very cheaply made and poorly design part.
I have lo luck locating this 5-button plastic switch assembly yet.
Be real carefule when separating the front bezel from the bac cover, it has very small ribbon cable attached to the front panel switch assembly that can easily be ripped apart.
http://s807.photobucket.com/home/budm/allalbums
Aug 18, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
My Dell 1905FP 19 monitor went black & green power light flickers
It sound like a short circuit. I had this problem with 1907FP model. It had an USB port on the monitor which got damaged and it was shortening to the groung. In your case it might be a bad internal power supply board.
Nov 20, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
DELL 1907FP MONITOR
Sep 06, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
I have a Dell monitor model 1704FPT,, seems like the power button has come loose inside.. Can I get inside to repair it .. Thank you
You can turn counter-clockwise the screwz at the back cover of your monitor to open it & check if the power button is loose or defective, even notice if some internal part/s are cold soldered / defective. However, if it's still under Warranty, I recommend to bring the unit to an authorized service center for a Free service check-up & replacement part/s. best regards
May 22, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
May 20, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
My dell 1905FP power button flashes green and will not turn off, the screen is black.
This is a common indication of a failure in the power supply. There are parts called capacitors that are used in the filter section of the power supply, when they go out the power supply can't properly turn on so you get no picture and a flashing power light. Here is a picture of the power supply board with the problem filter capacitors circled in yellow and below the picture in a link to a repair guide with details dis-assemble and repair instruction along with parts list for the Dell 1905FP and 1907FP models.
http://www.ccl-la.com/blog/index.php/repairing-a-dell-1905fp-1907fp-lcd-monitor/
Mar 25, 2009 | Dell UltraSharp 1905FP LCD Monitor
Dell 1907fpf will not power on.
Please search for "Power button stuck on Dell 1907FP" and see the advise from other members. I solved my by following their instructions.
Feb 15, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Height adjust for Dell UltraSharp 1907FP 19" LCD Monitor
Is it stuck, or just not adjustable? Try setting it on a phonebook. I'm kidding. If it is an adjustable base, sometimes they need a little downward pressure before the button will depress and allow it to move upward.
Thanks,
Chris
http://BoiseLCD.webs.com
Jan 03, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell UltraSharp 1907FP 19" LCD Monitor Logo
35 people viewed this question
Alun Cox
