Question about Ariens 34 In. Zoom Series Riding Mower
I have an ariens 1648 zero turn it only cuts with 1 blade instead of the 3
SOURCE: blades won't turn to cut grass
On the chute where the grass comes out there is a black piece of metal under the edge of the deck held on by the 2 big thumb screws is probably bent. You will need to try to move the blade on the side near the chute by hand (Make sure the mower is not running when you do this) if the blade touches the black piece of metal it will kill the mower if you engage the blades and try moving forward. Anyway you need to take the black metal piece off and bend the corner out of the way (I used a crescent and clamped it to the hitch on my pickup). I am guessing i went over something like a street curb with the deck when it was to low and that bent it. Now when ever I move the mower from someones yard or drive it across the street I always raise the deck up all the way. I hope this helps
Posted on May 27, 2009
SOURCE: I just installed mulch kit on my Ariens 34
i'm wanting to install a mulch kit too but it seems diffecult. hoew do you access under the mowing deck to install everything?
Posted on Sep 14, 2009
buffalonyman
  • 1865 Answers
SOURCE: ariens ezr1742 mower blades slow to engage and
Replace the belt
Posted on Sep 22, 2009
bbreton
  • 437 Answers
SOURCE: ariens zero turn will not start
Have you done a load test on the battery? It may be time for a new one 300CCA. Plus the solenoid may not be working right. you will know more because of lack of information or symptoms.
Good Day.
Posted on Nov 07, 2009
  • 509 Answers
SOURCE: Only one blade turns automatically on Ariens snow blower.
There is a bolt that goes through the center of the shaft that shears off if you hit something. You will need to line up the holes of the internal shaft with the auger tube and install a new bolt.
Posted on Feb 11, 2010
I was mowing with my 1648 ariens but it only mows on one side
Check for a loose free wheeling blade. If blade is tight try to spin the blade and all should turn. If the blade turns freely without the rest turning, the pulley may be loose and the key sheared off which means you need to pull the cover to do more checking which may require removing the deck. I hope this helps.
May 12, 2014 | Husqvarna Lawn Tractor  25 HP 54in Deck...
The little red button I pull to engage the cutting blades on my Ariens 1640 zero turn is not making them engage
Make sure all safety switches are in good condition then check the switch you are talking about. If you have a multimeter you can check continuity of this switch or you can go to a local dealer and replace switch. They aren't too exspensive.
Aug 09, 2013 | Ariens Garden
Turn zero
sorry but i would talk to the shop about that.
Jul 30, 2013 | Ariens Zoom 42 In 165 HP Briggs Stratton...
Blade number for Ariens Zero Turn Model 1840. Need
Depending on which version of the 1840 you have and when it was built it could be several blades...
Please get your model and serial number and then enter them into the following site's search engine. You should then be able to identify the parts you need.
http://partsradar.arinet.com/scripts/EmpartISAPI.dll?MF&app=ariens&lang=EN&TF=Empartweb&loginID=ariensc&loginpwd=consumer
John
Jan 18, 2011 | Ariens Zoom 42 In 165 HP Briggs Stratton...
Ariens 34 In. Zoom Series Riding Mower Logo
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
