Question about RCA Televison & Video
Why does my RCA VR667 not accept a tape and returns a eject or stop message?
  • RCA Master
  • 5,349 Answers
A couple of reasons. First the carriage the tape sits in is damaged. Next the mechanism that moves the tape is damaged and can't except a tape. Lastly or perhaps due to the later, the mode switch is faulty or not in the right position. The mode switch tells the electronics which position the mechanism is in, be it play, fast forward or eject etc. If the switch is faulty and stuck in eject then it wont except a tape.
Posted on Sep 18, 2015
ahhsoo69
  • 167 Answers
SOURCE: VCR does not eject tape correctly
hello. it's sound's like that the idler cam wheel that turn's the tape has a problem. it could be that .the wheel if made of rubber is slipping. or it has a belt on the bottem of it that is ***** out. check those two thing's .and let mre know if it has a rubber wheel .? or teeath that turn a gear. and if the belt on the bottem of it is not tight on the two wheel's on the bottem of it. let me know.ok "good luck"
Posted on Jul 03, 2008
ANTHONYPAULB
  • 17 Answers
SOURCE: JVC HR S5700AM S-VHS video recorder - won't accept tapes
Hey Lindsay
Yes the ejector is probably damaged inside maybe a bent arm or something mine is like that 2 and I didnt even bother fixing it I will be finding one very soon and I suggest you should 2 so just throw out the old and come in the new with your new vcr or dvd vcr combo..
Posted on Jul 23, 2008
  • 121 Answers
SOURCE: TAPE WILL NOT EJECT
Try unplugging the player from electrical power for several minutes. Plug the player back in and try to eject the tape.
Posted on Feb 26, 2009
  • 1170 Answers
SOURCE: Tapes won't go down, and then eject.
You are more than likely using a pre-recorded tape and a timer programis set to record. If you are trying to record, make sure the protectiontab is in place.
Here is the trouble shootingmanual.
Posted on Mar 24, 2009
  • 4234 Answers
SOURCE: Unit accepted cassette, won't eject
It is likely that either the drive belt has broken or is slipping. Because the unit is still in "play" mode, the mechanism won't let the door open up. If you have not opened up these units before, do not attempt it now. This unit should be taken to an experienced tech for repair. Where are you located?
Dan
Posted on Apr 08, 2010
Where is the eject button on RCA universal remote for DVD?
Universal remotes do not necessarily replicate all functions of an OEM remote. EJECT is commonly not one of them. You may have to eject right at your Magnavox combo.
Dec 17, 2015 | RCA Televison & Video
Rca on vcr is there sopose to be a green light underneath vedio taps wont play
If the unit will accept and load a tape but no picture and only sound works you have either a blocked video head or a bad head.
If it rejects the tape, tears it when you try to eject you have a mechanical problem which in the VCR could mean a bad belt or a drive mechanism problem.
Apr 02, 2012 | RCA Televison & Video
check the tips in my profile
May 10, 2010 | Sony EVC100 Hi8 VCR
TAPE WILL NOT EJECT
Feb 26, 2009 | RCA VR639HF VHS VCR
Samsung camcorder vp-d381 eject L fault
YOU CANT CLEAR IT. THIS SOUNDS LIKE THE TAPE TRANSPORT IS BAD. SOMETHING BROKE INSIDE TRANSPORT AND NOW IT WONT ALLOW YOU TO LOAD TAPES
Feb 21, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
Entire front panel does not work, but responds to control.
have you pulled the plug from the wall for a few minutes?
also, some vcrs will eject the tape when the RECORD button is pressed on the remote, and a tape is inside that has the record tab REMOVED!
good luck
Feb 07, 2009 | RCA VR622HF VHS VCR
Tape keeps getting ejected
This unit requires the rubber parts to be replaced. The loading sequence is not completing properly. The VCR will eject the tape when the sequence fails as a safety measure to prevent damage to either the VCR or the tape.
Parts cost for this should not be more than $10.
Dan
Feb 03, 2009 | RCA VR639HF VHS VCR
VCR won't accept tapes
VHS VCRs are not being produced in very large quantities any more. You may still be able to find a combo unit DVD/VCR.
The problem may be a belt or gear, or it may be that the tray is damaged. Only a tech can tell you, but there's little point in repairing these. I know Wal-Mart still sells them...
Ken.
Aug 07, 2008 | RCA DRC8335
Has power but wont play,rwd, fwd
retime the gears and check power supply
Aug 05, 2008 | RCA VR349 VHS VCR
VCR won't take tape
Is it ejecting the tape when you set up for timed record, or any record mode for that matter? If so, check for the presence of the record lockout tab in the tape. If tab is there, machine should accept it. If machine ejects tape with the tab present, then the sensor which detects tab present or absent is probably afoul. this sensor is often a small switch. This tab, by the way, is on the backside of the tape, on the left, looking at the tape from the back.
Apr 14, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Televison & Video Logo
232 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
