THE DRAINAGE PAN IS OVERFLOWING AND FLOODING THE FLOOR; WHAT IS THE PROBLEM AND HOW IS IT RECTIF- IED?
  • whttailtx Jun 24, 2009
    My problem is with a Soleus portable evaporative a/c which USED TO (1)discharge the moisture through a dual hose system; and (2) shut off the unit if the pan was full. Now it does neither.
  • whttailtx Jun 26, 2009
    Our "PORTABLE" AC is an upright unit, on casters, that can be moved from room to room. It is NOT a window unit. Two 4" corrugated hoses (intake and discharge)are attached to a window opening. I understand there is a type of heating unit that is responsible for discharging the moisture. Whatever is responsible for this function is not working.
    President:
  • 1,734 Answers
Ensure that you placed the unit on a leveled surface. If still water is leaking from the unit check if the drainage plug is loose. Make drain tube properly secured and plugged. Also check if the water bucket is full. If you need manufacturer assistance check here:
http://www.sylvane.com/customer-service.html
Posted on Jun 26, 2009
    President:
  • 1,952 Answers
Air conditioners have a cooling system identical to a refrigerator's. It is important not to turn the unit off and then back on right away. Wait at least ten minutes after shutting the unit off to allow the pressure in the refrigeration system to equalize once again. This will prolong the life of your air conditioner.
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
very air conditioner has a motor called a compressor. The compressor provides the cooling capacity for the air conditioner. If the compressor or its electrical controls are defective the compressor may try to start, fail, and create an electrical overload. If the unit does create an overload, every compressor circuit is also equipped with an overload safety switch. The safety switch is designed to protect the compressor from burning out. The safety switch will cut the power to the compressor for a certain length of time and then reset itself. When it resets it will allow the electricity to flow to the compressor once again. If the compressor then starts, the unit should function normally. If the compressor doesn't start when the overload resets, the overload will again cut the electricity to the compressor. This cycle will continue indefinitely. (Always allow three to five minutes before restarting the compressor.) If this situation is occurring, unplug the air conditioner and get help from a qualified repair technician. This problem is often fatal to the air conditioner because the cost of repair often exceeds the price of a new air conditioner.
All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
The condensing coils on an air conditioner will get very dirty over time. However, the dirt tends to accumulate on the inside of the coils, out of site. It will be necessary to remove the entire cover of the air conditioner to gain access to the coils. They can be cleaned by blowing compressed air at them or by using a soft bristle brush to wipe the dirt off. It is important to also clean any dirt or lint build-up in the bottom of the air conditioner so the condensate water will be picked up by the condensing fan slinger properly.
Posted on Jun 24, 2009
  • 10,515 Answers
First, make sure that it is the overflow.
AC units have a condensation line. This is a necessary option as cooling the air causes condensation, much like a cold glass of water will condensate on the outside of the glass. The condensate line should be draining to a safe place, and draining whenever the unit is running.
The unit should also have a secondary condensate line (overflow). this line should be separate from the main condensate line and be draining to a conspicuous place. If this line is draining, then you should check to see if the primary drain line is plugged. Anything from lint and dust to dead rats and mice have been pulled out of condensate drain lines.
If you do not know how to get to this, call a professional and use the primary and secondary condensate verbiage to let him know that you are not an ignorant putz that he can take advantage of. That should save you a few dollars on the bill.
There are some more points that might help you if you want to Fix it yourself :-
TIP 1 - An easy way to clear the overflow pvc pipe is to acquire a cheap sprayer at your local hardware store ($15). With this sprayer you pump it tightly with air only and then release the air into the pipe. Repeat this process multiple times into the pipe and you are golden! I learned this from my A/C man who promptly charge me $75 for his service call.
TIP 2 - Use the air compresor instead of pump sprayer. Also, since I capped my washouts with threaded couplers, I screw in a cap with a hole drilled just big enough to insert the air nozzle. A couple of bursts like you said and I could hear the water runnning through the drain which exits into the house plumming. The “shower” outside stpooed and the hole the leak made is drying out. Thanks again for the tip.
TIP 3 - If you can find a way to pour bleach and water mixture into the line, that might be enough to clear it out. If not, you’ll likely need to flush it with something more forceful like a blower or power washer.
Thanks for using "Fixya".
Posted on Jun 23, 2009
Had a patio put in and Contractor apparently did NOT hook up or install drainage pipes deep enough into the as my basement has flooded three different times
im not sure that the patio would have much effect on flooding in the basement
hi precipitation this year and a higher than normal water table which is the lvel below ground that if you dig into starts to fill with water.
your problem is more likely a drainage issue are there any sump pumps in your basement or does it at least have a floor drain if so perhaps there is a clog
call a plumber and the patio contractor and have a professional determine the reason for the flooding
ps you can purchase portable sump pumps you can set on a flooded floor and plug in and they will pump out water when the floor floods automatically
Simer 1/4 HP Portable and Submersible Utility Pump (4)
Questions & Answers (15) $8999 /each
Overview This versatile pump is lightweight and easily taken to remove water. Heavy-Duty Aluminum Construction for durability. Pumps up to 1320 Gal. per hour and comes with a male garden hose adapter. Home Improvement Made Easy with New Lower Prices Improve Repair
Feb 09, 2018 | Washing Machines
Why does drain pan overflow? How is water in pan suppose to go away before overflowing?
Are you sure it is the drain pan overflowing? If water is appearing on the floor every few days, it may not be getting to the drain pan (evaporator tray), due to a blocked drain channel. The evaporator tray will normally cope with the daily amount of de iced water of a frost free fridge/freezer.
Mar 07, 2015 | Refrigerators
Drain pan fills up and overflows onto floor
Is the pan "level" under fridge? If not, it will not hold the amount of drainage that is put out and spill onto the floor.
Goodman ac/heater drain pan leaking since instillation 3 years
sounds like the unit needs to be elevated and leveled.
Aug 10, 2012 | Goodman Heating & Cooling
I HAVE A 26 CU FT SAMSUNG REFRIGERATOR. WATER IS POOLING UNDER THE VEGETABLE DRAWERS. I WIPE IT OUT DAILY TO AVOID IT OVERFLOWING TO THE DRAINAGE TRAY IN THE VERY BOTTOM OF THE UNIT. THIS UNIT HAS A LOWER...
I wouldn't be wiping it up. I would let it go into the drainage pan. The design of refrigerators is that the drainage pan is placed by the condenser coils so that the evaporation of the water helps cool down the condenser grill, which increases the efficiency of the unit.
During this time of the year, your furnance is not taking the moisture out of the air so increased moisture in your refrigerator is normal because the air is more humid.
Jun 09, 2011 | Refrigerators
F-1 error message
Hi
F1 means the flood switch was activated for more than 6 seconds. This error is due to excessive water in overflow pan of the dishwasher. To remove this error you'll need to remove the excessive water. For this you'll need to take out the bottom overflow ray and remove all the water in it, you will see a grey plastic cover on the bottom floor this is the sensor. Turn on your hair-dryer and blow the air on this area for atleast 5-10 mins. You can remove the bottom drawer by pushing in the clips on side of the drawer. Please post back for any further assistance. Daniel
Aug 02, 2010 | Fisher and Paykel Dishwashers
Water leaking from bottom of refrigerator
THE WATER IN THE PAN IS FOR THE FAN WHICH COOL THE COMPRESSOR. MAKE SURE THE FAN IS WORKING. IT USES THE MOISTURE FROM THAT WATER TO COOL YOUR COMPRESSOR.
BOYNISMO@YAHOO.COM
Aug 10, 2009 | Kenmore 57029 Side by Side Refrigerator
Dishwasher motor runs (even with door open), but no Water
I believe the problem is in the electronic board. It is getting a different signal thus not allowing it to run properly. You can have a local service technician for the company look at it but this is probably the cause.
Dec 25, 2008 | Bosch 24 in. SHX46A05UC Built-In...
Bosch dishwasher model shu3300
Your machine has detected a "flood" condition and has defaulted to its flood mode. Meaning that only the drain pump will work until the flood is fixed.
Bosch D/W's are pretty slick, the entire unit is sitting inside a drain pan that's designed to catch an overflow (flood) keeping the water off of your floor. This overflow pan has a Styrofoam float that rises with the flood and trips the "flood mode". The water in the pan has to be removed allowing the float to drop back down before you can use your dishwasher again.
There are 2 ways to do this... the easy way and the hard way.
1.) Easy way---> Wait a few days. The water will eventually evaporate out of the drain pan all by itself. Takes longer than the hard way, but no tools are involved.
2.) Hard way---> (not actually "hard") TURN POWER OFF TO THE DISHWASHER! Remove the lower kick panels (below the door). Remove the 2 screws holding the water valve in place, and push the valve up as far as you can. Now use a "Shop-Vac" with a long crevice tool attachment. Stick the crevice tool in where the valve was... make sure to reach in there about 8 or 9 inches, (the safety float is in there on the left, you can see it with a flashlight) otherwise it won't reach the water. Now simply suck up as much water as you can. You won't be able to get it all, you just need enough removed to drop the float.
Now try your D/W... after a normal 2 minute drain, it should fire right up.
Nov 04, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
A.C. unit
One of the cause of water dripping in the indoor is restricted drainage. To Identify if your drainage is restricted.
- Turn "off " the circuit breaker and take out the face cover of the unit.
- Turn "on" the circuit breaker and start the unit, wait until the unit drips.
- When the unit dripped check the drain pan if overflowed with water.
- If the drain pan is full of water you need to flush the drainage with water to remove the restriction. If the pressure of water in your area is high you can use your garden hose to flush the drainage.
Another is dirty evaporator fins (icing), dirty drain pan, broken drain pan or incorrect installation.
YOU CAN LOCATE THE DRAINAGE AT THE LEFT OR RIGHT SIDE OF THE DRAIN PAN
Aug 16, 2006 | Carrier IBM UNIT 2380 79F4796 Drive Case
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
