Question about Imperial IR-6-C Elite Gas Kitchen Range
How do you light the IR-6 Imperial over pilot light
3 Suggested Answers
  • 125 Answers
SOURCE: where is the pilot light for imperial range oven
Hello. I will try to guide you, in the area that you described, there should be a pilot safety valve, and usually they have a red button you depress in order to get gas to the pilot. The pilot is usually beyond the safety, if you follow the pipe from the safety, into the burner area, that will lead you to the pilot. Put your match,lighter of choice there, while holding in the red button. wait approx. 30 to 60 seconds, then release. If all is well, your pilot is now lit, however you still may need some attention, like cleaning the pilot and orifice. If not, you will need possibly a thermocouple for the pilot/safety, or a safety. Either of those I would suggest you call a local service company, check your phone book under "restaurant equipment repair"
Hope that helps, and thank you.
Posted on Feb 22, 2009
  • 193 Answers
SOURCE: How do you light the
This range has a standing pilot light for the top burners and griddle top. If you look through the small hole under the flat top griddle you can see a small line about 1/4 inch that runs from the main gas manifold to the pilot light about 6 inches back under the griddle top. You will need a tightly wrapped piece of paper or a long match or small wooden stick, like a chop stick. Light the end of your paper, or stick and put it through the hole all the way to the pilot light. It should catch on fire. Whenever the main gas line is on, the gas will flow through the pilot light. If it will not light, there is a pilot light adjustment that is a very small screw in the middle of a 1/2 inch square metal fitting that is screwed into the gas manifold. If the pilot won't light, this screw may be turned all the way in, thus cutting the gas off to the pilot light. If necessary take a very small flat blade screw driver and turn the screw counterclockwise a half turn. That will increase the gas flow to the pilot light. Another way to light the pilot is to put your burning stick or match into the hole near the burner under the griddle plate, then slowly turn the heat valve to the on position. The main burner will light and then the pilot will light off of it. Don't get your face too close to the griddle when you light it, gas can flash back into your face.
Posted on Sep 23, 2010
HOW DO YOU LIGHT THE PILOT FOR THE OVEN? OVEN I
Remove the oven floor & the access panel below the door,inside of lower access panel their will a gas valve with a red button on it, push red button,light pilot burner connected to main oven burner,hold red button for 15-20 seconds,release red button and pilot should be on.reinstall panels
If you release red button and pilot goes out the thermocoupler needs to be replaced
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Imperial IR-6-C Elite Gas Kitchen Range
How do you turn off the oven pilot?
you have to turn off the main gas, or you can turn the pilot adjust screw, all the way off..clockwise,
i would not do the 2nd one
Dec 19, 2010 | Imperial IR-6-C Elite Gas Kitchen Range
How do turn on the pilot to the oven? and how do I know its calibrated correctly? I have an LP version
On this unit the pilot lights it's self when the oven needs heat as for checking the oven you can put a temp probe over the exhaust and it should read around 20'c less that it is set to
Oct 04, 2010 | Imperial IR-6-C Elite Gas Kitchen Range
How do you light the pilot for the flat top section of our Imperial 6 top stove?
Sep 23, 2010 | Imperial IR-4-G12 Elite Gas Kitchen Range
On my Imperial gas oven the pilot light ignites but doesn't start the burner
Do you push a red button to light the pilot ? Does the pilot stay on after you hold the button for 30 seconds ? Need more information. Could be the safety... could be the thermocouple....?
Tom
Aug 10, 2010 | Imperial IR-6-C Elite Gas Kitchen Range
Where is the pilot light for imperial range oven
Feb 22, 2009 | Imperial Kitchen Ranges
Imperial fryer
If your pilot lights up but the main burner doesn't light up then you have a bad pilot sensor or gas valve
Sep 16, 2008 | Imperial IFS50 Deep Fryer
Imperial Deep Fryer won't light
The pilot should not lower on main valve opening, this is a dangerous situation and should be handled by a pro.
Aug 08, 2008 | Imperial Kitchen Appliances - Others
How do I turn my oven on!
The oven pilot will need to be lit, On the bottom there is the oven safety valve, it has a red button on it, you must depress the button and hold it with the pilot lit for 60 seconds, when you release the button the pilot should stay lit and the oven will be ready for operation using the thermostat (knob). Please note: if the oven has set unused for some time you may need to hold the red button for a long time to bleed the air out of the lines. The pilots for the top burners are actually right beside each burner. You may need to turn these pilots on, they are controlled by small valves (small brass screws on the gas manifold where the gas valves and knobs are located, look between the knobs). These small screws/valves will open the gas flow to the pilots when turned counter clockwise. If you open these valves and the pilots still do not work, they will need to be replaced. Hope this helps
Nov 15, 2007 | Imperial IR-6-C Elite Gas Kitchen Range
Imperial IR-6-C Elite Gas Kitchen Range Logo
48 people viewed this question
Top Imperial Kitchen Ranges Experts
Dan Webster
Dan Webster
Thomas Perkins
Thomas Perkins
Are you an Imperial Kitchen Range Expert? Answer questions, earn points and help others
