Question about Electri-Chef 4400-EC-336-CB Grill
How to start the grill? - Electri-Chef 4400-EC-336-CB Grill
How do I use the grill function on my new microwave?
I've had an Emerson microwave/grill for about 5 years now and love it!! To use the grill function you just hit "grill/combo" then hit the buttons up above the grill/combo button for however many minutes or seconds you want, then hit "Start" button. make sure your using a metal dish.
Feb 20, 2016 | Emerson Microwave Ovens
Grill won't get hot
If you recently ran the grill completely out of gas, sometimes it creates a vacuum of sorts in the regulator. Shut the grill off, refill the tank. Open the valve from the tank first, then go through your normal starting sequence. Should clear it up. Good luck
Aug 14, 2012 | Weber Genesis Silver B Grill
Igniter won't start grill
could be a disconnected wire from the igniter. could be a bad ground. could be corroded. Is there a spark going across one of the jets? may need to resort to a butane grill lighter (cheaper than digging around and replacing parts.)
Jul 07, 2012 | Weber Q Grill
Grill slow to start, doesn't get hot
sometimes spider webs clogs the orifaces. also check your regulator .if its not making any sound give it a light tap with wooden hammer handle sometimes the diaphram sticks
Feb 24, 2012 | Viking VGIQ5323RE1N Gas Grill
Does not start. manual start doesnt work either.
First, is your grill on a cart or built in to an island? Secondly, are you using a 20lb propane tank to fire the grill or is it hard piped to the grill from your house? And finally, has it been converted from Propane to Natural Gas?
If you're using a 20lb LP Grill Tank are you sure there's still gas in the tank? Did you just installed a new, full tank recently and the problem started after that?
If the latter is the case, turn off the grill tank valve and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY, VERY SLOWLY, until it's fully open. Light each burner one at a time and turn then to high flame. Do the flames look normal? Are they the proper height? Is so, you just solved your problem. Remember to turn the tank valve on very, very slowly after turning it off each time.
If you grill is hard piped from your house, be sure that the gas line shutoff valve is turned ON.
Hope this helps solve your problem.
Feb 15, 2011 | ProFire PF27G Grill
Electric start does not work. Must be replaced.
Try replacing the hose and regulator, easy to do and inexpensive to start with.
Jul 11, 2010 | Weber Genesis Silver B Grill
My grill burners burn unevenly and usually too high. Adjustment?
If this is a natural gas grill, check to see if it has a regulator on the gas line. If it does not, you can install a regulator to reduce the gas flow.
Dec 01, 2009 | Char-Broil Commercial Stainless Steel...
My son purchased a GR10WSP1 house grill. He told
ibelivw that there is no on of switch, plugging it in cuts it on
Aug 14, 2009 | George Foreman GR30 Indoor Grill
Grill will not heat up
Same here i have no utter clue to the solution, only the main burner will light up if the other two are out and then when i flick one on they all die, it is a horrible instrument
Mar 19, 2008 | Brinkmann 810-2300-B Grill
Electri-Chef 4400-EC-336-CB Grill Logo
22 people viewed this question
Top Electri-Chef Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you an Electri-Chef Grilling Expert? Answer questions, earn points and help others
