Question about Boating
1991 johnson 150 hp starts great soon as motor is warm shaes violently loses all power. replaced thermostats and plugs what do i do next
No overheat alarm sounds acts just like overheating like only 3 cylinders
  • 1214 Answers
SOURCE: 98 328IS OVERHEATING AFTER CHANGING THERMOSTAT
Are you putting the thermostat in correctly? It it will not work backwards.
And to confirm that there isn't a different problem, take the thermostat out all together and see if it overheats.
Engine not fully warming up is not usually caused by the thermostat. Stats usually fail closed, not open.
You will want to check the water temperature sending unit or gauge after verify the water temperature with an external calibrated thermometer. You can attach and insulate the external thermometer to the housing where thermostat is located.
Reply back what you figure out. I will be happy to help you further.
Posted on Feb 03, 2009
chuck943
  • 783 Answers
SOURCE: My 2002 Ford Thunderbird is
You most likely have air in the system. These things can be a royal pain to get the air bleed out of the system.
Look back next to the brake booster and you will see a rubber tube with a screw cap in the end of it(this is the heater bleed), also on the front of the intake area you will see a black tube with an allen sloted cap.
Remove the slotted cap and screw the screw cc on the rubber tube. Add coolant to the coolant jug allowing the system to equalize until no more coolant can be added. Add as much coolant as possible to the engine fill( the sloted cap near intake). The heater air bleed will remain open.Replace the engine fill cap.Start the engine and turn the heater to MAX position.Close the heater air bleed when a steady stream of coolant comes from it, during engine idle. Allow the engine to idle for five minutes, add coolant to the degas bottle as needed to maintain the cold fill MAX mark.Reopen the heater air bleed to release any entrapped air and close again. Maintain engine speed of 2,000 rpm for 3-5 minutes or until hot air comes from the heater.Return to idle and verify hot air is still coming from the heater. Set the heater temperature setting to 75° F and allow the vehicle to idle for two minutes.Shut the engine off and allow to cool.After the engine has cooled, add coolant to the degas bottle to bring the level to the cold fill MAX mark. This should have the air out of the system.
Posted on Mar 02, 2009
SOURCE: 1991 ford tempo is overheating resulting in loss of power
replace the car. the ford tempo and the mercury topaz are bad cars .you will always have trouble with these cars.
Posted on May 22, 2009
SOURCE: Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Posted on Jul 25, 2009
  • 34 Answers
SOURCE: My 2002 Chevy Malibu is overheating. I found that
If your car is equipped with a 3.1 or a 3.4 litre V6 and you have preformed all of the above listed work then I would have to say its the intake manifold gaskets. They commonly blow on these motors. Just a design flaw, nothing but replacing them when they leak can fix this. Also run a coolant pressure test on the system to check for minor things like a leak that you cant see from visual inspection. Hope this helps.
757Nate
Posted on Nov 21, 2009
My dad has a 1973 Johnson 25hp outboard that has been sitting for the past 5-6 years. When I try to start it, it's really hard to pull with the plugs in, easy with plugs out.
The biggest problem is the internal bearings. On an outboard, they are all roller and/or ball bearings. If the pistons stick it is not as big a problem as rusty bearings. It sounds like you have some great compression. (hard to pull with the plugs in). I recommend you visit with a local dealer who is familiar with this older model. A little care in getting it restarted (carb, fuel pump, water pump impeller) can help resurrect the motor. Also if they know these motors the can assess the internals without disassembly. It may need a tear down but without knowing more it is hard to say. I live in south Florida.
Jul 26, 2015 | Evinrude / Johnson 135-150-175-200 HP...
Why does my 1995 f-150 die after it warms up
Check coolant level,could be thermostat or radiator plug up,tune up.
Oct 20, 2014 | Ford F-150 Cars & Trucks
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
Johnson 1998 175 hp motor seems to be in safe mode
U CAN DISCONNECT THE OIL RESOVIOR SWITCH THAT TAKE IT OUT OF SAFE MODE BUT IM LEANING TOWARD THE POWER PACK
Jul 12, 2009 | Light Outboard Motor Boat Bass Fishing...
Jun 25, 2009 | Boating
1998 GMC sierra 5.7 warms up to violent shut down
I Would Look Into ECM Probled As It Takes over when the Engine reaches 195-220 Deg the ECM Takes Charge of Timing ETC.
Jan 31, 2009 | 1998 GMC Sierra
Outboard motor won't run under load
I have 1969 5hp Johnson. Starts and runs good, but will only push a 14ft row boat slow at low to medium rpm. When at higher rpm the the motor just revs up and the boat slows down to almost nothing just like it has seaweed around prop.Any help would be great.
Jan 19, 2009 | Boating
Johnson Outboard Motor 175HP
Not knowing what year it is...Light and alarm? Reason: overheat low oil etc. check water flow..water pump. The motor is most likily going into S.L.O.W mode. its a fail safe system. Last possibile reason ..CDI box and or stator.. pull plugs check compression...should be 120-150 lbs.
Jan 06, 2009 | Boating
Boating Logo
67 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
