Question about Royal HG140MX Shredder
Power light is on but will not shred
Won't shred even if pushing forward/ reverse buttons doesn't make a noise, and is not overheated
FixinFax
  • 3085 Answers
SOURCE: I was shredding some old check books and jammed
Try soaking the clogs with hot soapy water overnight.
Soap disolves paper.
Posted on Dec 23, 2009
  • 1218 Answers
SOURCE: shredder won't shred forward but works in reverse
Either the "eyes" are dirty or faulty, or the pcb has gone. Call Royal at 1-800-524-0799 for parts availability. When you get it working again only run the unit at 70% of its max rating... this provides less stress on the motor and internal parts.. the machine will last longer and you will have fewer jams.
Posted on Aug 14, 2010
  • 1218 Answers
SOURCE: shredder works but when I
Try cleaning the "eyes" in the middle where you put the paper in...they may be dusty/dirty....if that dosnt fix it you may have pooched the pcb inside...contact Royal at 1-800-524-0799 for Parts assistance.
Posted on Nov 19, 2010
  • 1218 Answers
SOURCE: my shredder will only show the green light when in
Take it back to the store where you got it if it has never worked...its probably still under warranty.
Posted on Dec 18, 2010
  • 1218 Answers
SOURCE: shredder will not automatically shred
Try cleaning the little glass "eyes" in the middle where you put the paper in...they may just be dirty.
Posted on Mar 30, 2011
Omnitech wont shred papers.
Sounds like its jammed? Have a really close look for staples, paperclips etc stuck in the drive gears or blades
May 19, 2015 | Office Equipment & Supplies
My Black & Decker Shredder #BD-61 all of a sudden does not work. I used it tonight, but the next time I tried it does not work. The lights come on in both positions, but
On some shredders when both the forward and reverse LEDs are on it can indicate either a jam or a full receiver bag/ container (the area that the shredded paper is fed into).
Try the following steps:
  1. ) unplug the power
  2. ) open up the shredder (see 1 on diagram)
  3. ) empty out all the shredded paper (see 2 on diagram)
  4. ) check that the shredding jaws (both the entrance and exit) are clear of any shredded material (see 3 on diagram)
  5. ) put everything back together
  6. ) plug power cord back in
  7. ) force the shredder into reverse (see 4 on diagram)
Hopefully you should hear your shredder motor running. If it is switch it to automatic and try shredding again
Jan 24, 2015 | Shredder Office Equipment & Supplies
My shredder will only work in reverse.
There must be a button on the shredder you need to push so it works forward, this button has 2 options: forward for shredding, and backward to push caught papers out of shredder.
Jul 07, 2014 | Cross Royal 7 HT700X Shredder
My shredder runs non stop, when I insert paper to shred , it stops... I push reverse, it works , pull paper out and runs non stop.......
Sounds like a bad or stuck sensor, acting as if it is always seeing a peice of paper in it. Check if you can find it and maybe it is just stuck to the on position..
Nov 07, 2013 | Omnitech 10-Sheet Micro-Cut Shredder
Hello my nane is Tom. The shredder doesn't work. It will run in reverse but when I turn it to forward it run for a second or two than stops. I looked and I can't see anything jamed in it.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Aug 30, 2011 | Aurora Electronics AS662C Shredder
Dec 23, 2009 | Royal 160MX Shredder
Paper gets jammed. Even shredding just one sheeet of paper. Clicking noise is heard before the red light comes on.
The problem was solved by putting some oil on the top of the shredder and running the motor forward and in reverse to coat the teeth. Thank you.
Oct 16, 2009 | Fellowes DM8C Cross-Cut Shredder
Shredder won't shred any more.
I have the Infoguard SX100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, red side switch, the gears and fuse were all ok, I think something on the circuit board was fried.
I switched the BLACK and WHITE wires with each other going to the shredder motor, thus when I switched it to reverse, it would go foward and shred. Its working now, only in reverse.
Mar 27, 2008 | Office Equipment & Supplies
Royal HG140MX Shredder Logo
146 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
