Question about Whirlpool DU912 Dishwasher
Proper way to unclog drain - Whirlpool DU912 Dishwasher
My Elkay water fountain is clogged up, water does not drain properly, how do I unclog
To unclog the elkay water fountain just look out for push button catridge and and turning it to adjust how far it is pushed or you can even try with chemical drain cleaners like draino or liquid plumber or CLR(Calcium,Lime and Rust Remover) & if still the problem hire plumbing repair services.
All Plumbing Repairs
Apr 29, 2015 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
I have wm1814cw lg front loader washing machine with oe light on and not draining we have clean filter unclogged drain hose and reset by unplugging and holding down power putton and start button als
The OE error or fault code indicates that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Sep 16, 2014 | LG Washing Machines
How do you unclog washer drain
Hey friend, thanks for your inquiry!
I understand that you would to unclog your drain on your Frigidaire washer. I would recommend having a professional come out to unclog your drain because this would acquire some disassembly of your washer. These intricate parts do require precision and patience and I would suggest having a technician come out to avoid any potential harm. -Matt
Aug 22, 2014 | Frigidaire Washing Machines
How to unclog KFCP22EXMP drain line
You could... run a pipe cleaner upward from the drain tray, Jeannie. I'll bet that it's frozen, though.
Aug 12, 2014 | KitchenAid Pro Line Series Counter Depth...
Unclog a/c drain on mitsubishi ductless mr. slim
you should have a drain on the outside of the house take a shop vac and suck this drain line out, Make sure your filter is clean.
Jul 15, 2014 | Mitsubishi MS-A12WA & MU-A12WA Mr. Slim...
My dishwasher is draining properly.
yes there is cleaners.Check filters at bottom of machine fiirst,then buy an cleaner.adrian,,,,
Jul 15, 2010 | Whirlpool 24 in. DP940PWP Free-standing...
How do I unclog the A/C drain on a 2000 Buick Century?
in order to do a proper clearing of the drain u must remove the blower motor under the dash on the passenger side behind the glove box. then the drain is at the bottom of the housing the blower wheel sits in..
Jul 02, 2010 | 2000 Buick Century
PTC22MFM - need to unclog defrost drain?
Normally, this is a job for an appliance service company. However, turn off the refrigerator and remove the rear freezer panel. Once removed you should see a drain hole. Apparently, water does not drain properly. Use an extended coat hanger, etc. to place down into the drain hole with "up and down motions". Periodically, pour a small amount of water into the drain hole until it appears to be unclogged. Then follow up with some hot water and liquid bleach (perhaps a cup full). This should kill any algae, etc. and remove any other foreign objects from the drain line. If you pour too much liquid into the drain hole you may get an overflow at the bottom of the refrigerator (there is a small drain pan underneath the appliance that catches the water during the defrost cycle. Yet, the water collected in the drain pan, during the defrost cycle, typically evaporates and you should never have to regularly empty the drain pan. Good luck!
Feb 20, 2010 | GE Refrigerators
Water appears at the bottom shelf below vegggie draw, but there is no place above it or elsewhere that is the slightest bit wet, no place from which it is dripping or flowing from that is evident. There is...
Hi ,
Maybe this can help (if it is a no-frost type refrigerator )
Try to locate the drain trough, which is located just under the freezer -section panel sepparator ,at the back (in the refrigerator section)
Prey it out ,clean it ,push a flexibile rod in the drain line to unclog then replace the drain trough.
Or look for a drain hole just above the veggie shelfs on the elevated part,Try to unclog it with a proper tool.
If neccessary mail me jvclean@gmail.com
Mar 06, 2008 | Refrigerators
Whirlpool DU912 Dishwasher Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
