Question about Stihl Blower Exhaust Muffler Spark Arrestor Screen Br 106 Br106 4222-141-9000
Remove spark arrestor on a BR 380 blower - Stihl Blower Exhaust Muffler Spark Arrestor Screen Br 106 Br106 4222-141-9000
Fix carb on gas blower 175mph
Check the spark arrestor screen located in the muffler for blockage. That is a textbook symptom for a clogged spark arrestor.
May 26, 2014 | Homelite Garden
Engine will not go to high speed fuel oil mist blows out .checked spark arrestor ,muffler,exaust ports.
If the mix is blowing out the muffler than it is flooded either due to improperly adjusted carb, stiff diaghrams in the carb or weak spark. Weak spark could be a bad plug, failing ignition module, or spark ouit of time ( sheared flywheel key).
Bad fuel will also cause this symptom.
Oct 25, 2012 | Troy Bilt Tb320bv Spring Assist Blower/Vac
My weedeater leaf blower never gets up to its' old speed. Runs about 1/2 the power. Tried a new spark plug and air filter. New gas didn't help.
Basics to check:
1) Spark plug - brown or dark brown - OK
- aluminum or silver - piston/cylinder scored
a) is it carbon or fuel fouled
b) is there spark
2) Compression - 125 to 150 psi
3) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 11, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Gas blower won't start
1) spark plug
Remove Carburetor
Nov 11, 2009 | Poulan Featherlite Gas Blower, with Low...
Blower starts but shuts off in run
1) spark plug
Remove Carburetor
Nov 10, 2009 | Garden
My blower shuts off when i excell the trottle
1) spark plug
Remove Carburetor
Nov 09, 2009 | Echo Garden
My craftsman leaf blower will not start.
Basics to check:
b) is there spark
1) spark plug
Remove Carburetor
Oct 30, 2009 | Craftsman 4 Cycle Blower/Vac
This Model 358-797251 Leaf Blower will not start. What can I do to make the engine run at the regular speed?
Basics to check:
b) is there spark
1) spark plug
Remove Carburetor
Oct 19, 2009 | Craftsman 4 Cycle Blower/Vac
Echo PB 2100 Leaf Blower will not speed up
Remove the muffler and clean the exhaust port, spark arrestor screen and muffler intake.
Apr 09, 2009 | Garden
Stihl Blower Exhaust Muffler Spark Arrestor Screen Br 106 Br106 4222-141-9000 Logo
159 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
