Question about Smeg Ovens
What is Error 5 on Smeg SCP109SG8 Pyrolytic Oven
Hi I turned my oven on tonight and it heated up and beeped as normal. a few minutes after when I went to put food in, the whole thing had shut off and tripped the fuse box. Reset the trip and oven keeps coming up error 5. this isn't in the instruction manual. please help
  • 236 Answers
SOURCE: smeg oven suk92mfx5
ring element has burnt out.
Posted on Feb 16, 2008
  • 4 Answers
SOURCE: message panel keeps flashing F10 error
Code F-10 indicates a temperature runaway. There are two possible problems. 1) The oven temp sensor has failed. This can be checked using a standard multimeter. The sensor is located behind the rear access panel of your oven. The sensor should read about 1100 ohms at room temperature. 2) The oven control board needs to be replaced. There are no FRU's (field replaceable units) on the control board. Check the sensor first. Even a new control board is cheaper than a new oven.
Deepwater
Posted on Apr 30, 2008
shanat
  • 359 Answers
SOURCE: MAIN HOUSE FUSES TRIPPED, RESET, OVEN AND GRILL WILL NOT HEAT UP
sounds like the fan element this link will help http://www.ransomspares.co.uk/elements.asp?search_fd6=XOU252
Posted on May 26, 2008
barkencoa
  • 3463 Answers
SOURCE: Smeg oven not working
You have a element and or a faulty thermostat
Posted on Nov 25, 2008
barkencoa
  • 3463 Answers
SOURCE: SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Posted on Dec 15, 2008
Got error "pyrolitic interrupted" any way to clear this swithed of power for 24 hours to no effect
A feature of certain Smeg ovens, Pyrolytic cleaning is an automatic cleaning function which works by heating the inside of the oven to 500°C, at which temperature any grease stuck to the walls is simply burned off.
i think something is wrong with the elements
or a sender / sensor
so as its telling the controller for the oven that its not getting to the right temp perhaps one half of the oven isnt running etc
perhaps some sensor has become worn at these hi temps i cant see a senor lasting more than a few years before it degrades
May 05, 2015 | Ovens
Circuit board failure
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Mar 24, 2011 | Smeg F170 Pyrolytic Stainless Steel...
I have a new (about 7 months old) SMEG SAP112-8 60cm Linear Pyrolytic Oven. The knob to turn the oven on does not seem to work. You usually push it in (and meet some resistance) to turn the oven on, then...
We have experienced the same problem. We have a service tech coming to fix it. The knob has come off. It seems that the internal spring has dislodged itself. This will be claimed under warranty. Ours is 5 months old. Our other Linear combo oven and coffee machine seem to be more solid/sturdy.
Dec 24, 2010 | Smeg Linear Pyrolitic Single Oven Electric
Cleaning oven got a warning beep and an F1 indicator in light panel
F1 error code normally means the oven temperature has exceeded the safe limit for the oven and the beep is to warn you to switch off until it has cooled down.
Normally this is caused by failure of the oven temperature control sensor which then fails to cut off the power to the heating element as it should.
Sometimes it is just a 'glitch' wich can be solved by turning off the power to the oven for a few minutes and then turning back on but if the problem persists you will need to replace the sensor.
Jan 12, 2010 | Jenn-Air Ovens
Pyrolytic cleaning won't start. Neff B15P42.0 GB
you have to remove the shelf supports (left and right) as well as the shelves. The manual tells you about the shelves but not the supports. I only found out as someone wrote the answer on another website
Sep 10, 2009 | Neff B1476 Pyrolytic Stainless Steel...
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
Smeg F170P-5 Oven
Models with analogue/digital programmer feature a "DEMO" function which deactivates the heating elements while leaving the other functions unchanged. To activate it, simply press the bell (minute minder), - and + keys for 3/4 seconds. A confirmation beep will inform the user that the function is active. To deactivate it, simply repeat the same procedure. This worked for my Smeg SC399X-6.
Aug 17, 2008 | Ovens
Smeg oven problem
The pop would usually mean a busted fuse. Turn off the oven, disconnect completely from the power supply and then take it apart. See if you can find any toasted fuse or roasted wires. Also the reason for tripping the mains off is due to the fact that the oven is draining more power than it should. I would recommend a thorough inspection of the oven by an electrician..
Jun 18, 2008 | Smeg SE399X/5 Stainless Steel Electric...
FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Dec 14, 2006 | Smeg F170 Pyrolytic Stainless Steel...
Ovens Logo
158 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
