Question about Sewing Machines
Foot pedal 141 capri singer sewing machine - Sewing Machines
  • 323 Answers
SOURCE: SINGER LIMITED EDITION-MODEL 6268
More than likely you need a pneumatic transducer. It's the part that your air tube connects to and that is what actually makes your machine run.
sewman7
Posted on Oct 25, 2008
  • 323 Answers
SOURCE: foot pedal assembly for White sewing machine
You only need to replace the cord if it has been damaged. It will cost less if you just take the machine , cord and control to a local technician and have him just replace the foot control. Let him test it first. A generic foot control should cost less than $30.
sewman7
Posted on Dec 29, 2008
  • 980 Answers
SOURCE: singer 522 starts sewing at speed without the
Undo the foot control and take out the small square suppressor and throw it away, you don't need it anymore.
Posted on Dec 18, 2009
SOURCE: My foot pedal started smoking on my Singer 413 Sewing Machine
Hi.
No solution I'm afraid - but it has just happened to me too on a 1975 singer 522 Machine. Like you just switched it off and am now sourcing a new pedal....did have a look inside the pedal but nothing obvious - smells horrible though and will not use until replaced.
Posted on Feb 14, 2010
SOURCE: wiring a foot control pedal for Singer
I have a singer advance 7422 and the outlet for the foot controller is kind of broken. A few days ago a little round black thing fell out of the outlet and now when i try to connect the foot controller it is very loose and the machine doesn't run. what should i do?
Posted on Jun 28, 2011
How do I fix my singer 6333? I plugged it in the light comes on the foot pedal is attached but no air coming the machine to the foot pedal therefore no sewing action how do I fix it?
There are some sewing machines that the foot pedal is driven by air pressure. Sometimes they will develop leaks so the air does not build up enough pressure to activate the machine. You might see about finding a replacement foot pedal--however if that is not the problem, you may waste your money. Perhaps a sewing repair shop can help you.
Oct 28, 2015 | Singer Sewing Machines
Where can I find a power cord for singer simple 3116 sewing machine?
It looks like your power cord and foot pedal are incorporated into one unit, and you'll have to replace the foot pedal to get it. You can get it for $30 at sewing parts online, http://www.sewingpartsonline.com/singer-3116-simple-sewing-machine-parts.aspx?gclid=CLTXmrLC18ECFeHm7AodBioADg, and you can also get them from eBay by doing a search on Singer Simple 3116.
Oct 16, 2014 | Singer 3116 Simple
Wiring diagram model 7466 i am trying to reconnect a foot pedal on my singer sewing machineu
The foot pedal is generally plugged in on the right side of your machine. There should be a hole that matches the end of the plug. The user's manual is available as a free download on Singer's site.
Sep 22, 2014 | Singer Sewing Machines
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
Foot control makes singer 507 over run
On that machine I would just replace the foot pedal.
Aug 13, 2012 | Singer Sewing Machines
Sewing Machines Logo
19 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
