Question about Audi Vehicle Parts & Accessories
Where is location of camshaft postion sensor on 93 ford explorer 4.0
    Master:
  • 710 Answers
In the head near the camshaft.
Posted on Sep 01, 2014
Edge. where is crankshaft position sensor located?
Hi Rusty, There's two links below showing the position of 2005 Ford Explorer Crankshaft Position Sensor and the 2008 ford edge camshaft sensor location. It seems like they're all in the same position, I hope this helps.....CHEERS
2005 Ford Explorer Crankshaft Position Sensor Location
Apr 02, 2016 | 2003 Ford Ranger
Where is the camshaft postion sensor on the 07 ford edge with the 3.5 v6?
Locate the cam sensor wiring harness from underneath the vehicle at the front of the engine block near the crankshaft pulley.
Read more : http://www.ehow.com/how_5686466_change-ford-cam-sensor.html
Jun 12, 2014 | 2007 Ford Edge SEL Plus
My camshaft sensor on a 1999 ford explorer needs to be replaced
It's located on top of the driverside valve cover next to the oil fill cap, theres a metal clip holding the connector,push it down and it will pull off,then remove the 8mm bolt and twist it back and forth while pulling at the time.
Feb 23, 2013 | 1999 Ford Explorer
Engine stalls at 30mph upon hitting accellerator, then coasts to a stop. then won't restart. starter works, engine turns over, but won't fire up. next morning car starts fine. next week engine...
Hello first of all
well i am sorry a mechanic cant figure this out its really sad. ok so your problem is your either one of two things but most likely the first one i list.
1. camshaft postion sensor
2. crankshaft postion sensor
Now that being said it most likely the camshaft sensor the reason i say that is when a crankshaft postion sensor is bad the car has very hard starts and most of the time no start issues. When a camshaft postion sensor is bad the car cuts off whil driving and can be hard to start up again.
So that being said they are both pretty cheap parts i would go ahead and replace them both and i would bet my 5 years as ford mechanic that solves your issue.
The crank postion sensor is located behind the harmonic balancer pully or right beside it here is a picture from autozone.com and description.
The crankshaft position sensor identifies position of the crankshaft to the ignition control module (ICM), engine control module (ECM) or powertrain control module (PCM).
  • When not replaced, vehicle could experience no- or hard start, long crank time, misfire, lack of power, excessive hydrocarbons in oil, spark plug fouling, catalytic converter failure, poor fuel economy, CEL/MIL illumination or intermittent shutdown.
  • Designed to meet or exceed OE specifications in form, fit and function.
  • Global coverage for import and/or domestic applications.
  • jamiesturm29_6.jpgAnd the camshaft sensor picture and info from autozone.com below.
    The camshaft position sensor identifies position of the camshaft to the ignition control module (ICM), engine control module (ECM) or powertrain control module (PCM).
    The crankshaft postion sensor is 22.99 and the cam is 19.99 so 50.00 bucks and about hours time should have you up and running.
    PS if this helps please 4 thumbs up it helps me continue to help on here thanks
    May 19, 2011 | 2006 Ford Crown Victoria
    1998 ford explorer speed senser cam-shaft pulley WERE IS IT LOCATED
    Sorry you said camshaft sensor look behind the intake manifold back next to the firewall the sensor should be their but, i don't no about a pulley but there is a camshaft synchronizer beneath the sensor itself.
    May 11, 2011 | 1998 Ford Explorer
    How do check the CPS on a 2000 Ford Explorer?
    you cannot check crankshaft postion sensor if your car has hard starts or does not start your crankshaft postion sensor is faulty it tells cars pc when to fire spark and to what cylinder to fire it to
    if it helps please leave a 4 thumbs review if it helps
    May 10, 2011 | 2000 Ford Explorer
    How to replace 2002 ford explorer camshaft sensor
    On the 2002 ford explorer the camshaft postion sensor is located on the left (driverside) cylinder head near the top, heres a diagram to show you where its located. hope this helps,20eb997.gif
    Jun 12, 2010 | 2002 Ford Explorer
    Where is the camshaft sensor located on a 1996 ford explorer 4.0 literand where is the egr valve located also
    cam sensor is located rt side of engine half way up egr is left side of engine front ove valve cover
    Mar 03, 2010 | 1996 Ford Explorer
    Vehicle Parts & Accessories Logo
    Top Audi Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    ray gallant
    Tom
    Are you an Audi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
