Question about HP Officejet 6100 Eprinter - H611a 1 Year Warranty
Take apart a HP 6100 for return
Remove paper tray
4 Suggested Answers
  • 521 Answers
SOURCE: I have a hp photosmart
exactly at the back side of the printer there is a plastic rectangle in shape you have to gently press and remove that plastic rectangle tray outside and then you can easily remove the jammed paper.
Posted on Aug 08, 2008
dj_relly999
  • 4070 Answers
SOURCE: my hp 6100 all-in-one takes
Hi! Please try this. Unplug the printer from power source then press hold the power button for 10secs. while unplugged. This should reset the printer's system. Plug the printer, turn it on and see how it goes. This should be working properly. Hope this helps and thank you for using FixYa!
Posted on Aug 20, 2010
  • 794 Answers
SOURCE: how do you remove paper
Hi we2halls,
You may want to try the procedure on this link to help you clear the "Paper Jam". It includes detailed instructions and some illustrations.
Hope it helps.
Thank you for using FixYa.
Posted on May 04, 2011
Stating that there is no paper but there is paper in the tray
Usually this means that the paper can't be picked up. First take out the paper and check for curled edges or wrinkled paper. Discard damaged pages. Check for torn corners and remove any small foreign objects. Make sure that the paper is aligned properly when you return the paper to the tray. If you only have a few sheets in the paper tray, add more paper.
Next check if the rollers are dirty. They can be cleaned with a damp lint-free cloth. (Just a little water is needed.) Check that the feed mechanism is undamaged. My home inkjet printer (an HP OfficeJet 7000) had a part of the paper lift mechanism break a few days ago. If you pushed the top sheet of paper just right, the printer would still pick it up. We noticed a loose piece when we opened the back of the printer for the straight-through paper feed. After attempting to replace that piece, we looked closer and another part fell out of the printer.
Some find it worthwhile to take apart the printer and re-attach the parts. If the printer is still under warranty, let HP do the job.
I hope this helps.
Sep 12, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
Paper jam. How do I get the paper out. my instructions don't tell what to do. This is HP Officejet J4680cAll in One
http://h10032.www1.hp.com/ctg/Manual/c01770356.pdf
Follow the instructions on how to "To clean the plastic strip inside the automatic document feeder" This is the closest you will be able to get to getting inside the paper feeder to check for the paper jam.
Feb 28, 2011 | HP Office Equipment & Supplies
My officejet 5610 says "carriage jam. Open Door etc. I can't find a door to the carriage.
Hi!
here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is on.. open the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.
look inside the product..check for torn papers..gently pull out the paper from the roller...return the paper output tray and the carriage access door. plug the power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriage access door.
disconnect the power cord from the back..remove the paper output tray...look inside if the carriage is stuck and if there is no papers or object that restrict the carriage to move..return the output tray.. return the carriage access door...
And lastly after doing this steps try to reset the printer and try to print..
To reset the printer....press the power button to turn on the printer..disconnect the power cord from the product..disconnect the power cord from the wall outlet.. wait for 15 seconds.. plug the power cord to the wall socket....plug the power cord at the back of the printer.. press the power on of the printer.. try to print the test page...
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
May 23, 2010 | HP Officejet 5610 All-In-One InkJet...
Adf jam hp laserjet 3055
Here is a link to view or download the Service/Repair Manual. It details how to tear the whole thing apart if you need to.
Laserjet 3055
Sep 17, 2009 | HP LaserJet 3055 All-In-One Printer
My HP 6100 series all in one wants to align cartridge
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Xerox 6100 laser - paper jams if paper tray low on paper
There could be two things. First, be sure the paper tray is not binding. The metal plate in the middle should spring up easily. The friction pad should be firmly attached to the tray, but not extending over the metal portion. The second thing would be to clean or replace the feed rollers. They are inside the machine above where the tray would sit. Since the tray feeds when full, I don't think you have a clutch problem. Let me know how it goes.
Jun 10, 2008 | Xerox 6100/DN Laser Printer
Hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
HP Officejet 6100 Eprinter - H611a 1 Year Warranty Logo
66 people viewed this question
Seeker5211
Seeker5211
