Question about Vizio P2 42 in. HD-Ready Plasma Television
Vizio 32" HDTV10A aspect ratio problem
I just won a Vizio 32" HDTV10A in a raffle. I hooked up my cable box and dvd player, but the aspect ratio isn't working correctly. The normal view is fine, but when I switch to the Wide view it just stretches out the entire frame instead of enlarging it to fit the 1.85:1 aspect ratio that a lot of movies, and now tv shows, have. Basically, it makes it look nearly exactly the same as the Panoramic view. Any assistance is greatly appreciated.
  • Anonymous Dec 21, 2007
    I can't figure out how to fix the aspect ratio. It's zoomed in and there's no way to get it out.
  • Anonymous Nov 12, 2008
    we have the same problem on our 26" Vizio HDtv. Cannot figure out how to fix it. Resetting options to factory setting did not help.
3 Suggested Answers
  • 139 Answers
SOURCE: Vizio VW32L HDTV10A stopped responding with Vizio
Change the batteries in your remote. If your cat was laying on a button it could have drained them.
Here's tip - you can use your camera on your cell phone to see the IR signal coming out of your remote. Point the remote at your cam and press "On" or any button. You should see a bright flash with every key stroke.
Posted on Mar 06, 2009
maatmartin7
  • 1213 Answers
SOURCE: CUSTOMER WITH A BRAND NEW VIZIO VA 320M KEEPS SHOWING SIDEBARS
The signal board is bad. Replace this board, its the one with the rca jacks and rf connectors. Warranty work will cover this repair. As we say in Nebraska.......Getter Done!!!!!
Posted on Aug 12, 2009
Change screen from wide to regular our cable guy put it on wide my control will no longer change it
Vizio has a set of buttons on the left side where you can access your settings and change the aspect ratio of your TV. Though why you want it changed is beyond me. Wide screen is for 16:9 aspect ratios. At 4:3 (Standard) you won't be using your full TV picture.
May 19, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
What cables do you need to connect a dvd player to a vizio hdtv
If your dvd player has a hdmi hook up "easy" just use 1 hdmi cable from the dvd player to the tv. If not use the 5 cord for better picture quality.
Nov 08, 2009 | Vizio L32 32 in. LCD HDTV
Aug 12, 2009 | Vizio L32 32 in. LCD HDTV
How do I adjust screen so it doesnt cut off top and bottom. It does it in every aspect other than normal
you may have the tv hooked up to a cable or satelite box that has it's own built in aspect ratio that is set on stretch or zoom.
Jul 13, 2009 | Polaroid 3211TLXB 32 in. LCD Television
Onkyo TX-SR606 aspect ratio issue
you may want to try changing the aspect ratio on the HD box and the DVD as opposed to the receiver. This should do the thing
Mar 04, 2009 | Onkyo TX-SR606 Receiver
Picture is to tall. it cuts off the top of the heads
It sounds like you have the image on the perspective. If you tv is 4:3 aspect ration the video source (cable box, dvd ) must be set for a 4:3. If you have a 16:9 ratio (widescreen) the soutrce should be set to 16:9..................Nevermind, Just looked it up you this TV is 4:3.
Your TV remote will have a button to toggle/change the aspect ratios of the TV. Button could be called picture/aspect/image etc. If you have an HD cable box you need to go into the video setting and chnage the aspect ratio to match the 4:3 tv.
If you need more help, please respond with more deatils.
Jan 19, 2009 | Sanyo DS32830H 32" TV
My picture 37" vizio hd tv does not fill in the whole screen when watching an HD channel
you need to change the aspect ratio on your cable box from 4:3 to 16:9. sould be under menu/setting/. if not try using the format button on the remote. hope this helps
Jan 02, 2009 | Vizio L32 32 in. LCD HDTV
No signal when hooked up with a digital cable box
turn your tv to channel 3 and then try 4 one of these should work . Also make sure that you have it plugged in the right coax jack in the back
-Josh
Mar 05, 2008 | Vizio L32 32 in. LCD HDTV
I cannot change aspect ratio
If you are trying to change the aspect ratio on the television make sure you are sending an HD signal Via Component cables. I am not aware of a way to get HD cable without a PC cable card or box, it could be that your television is not receiving the proper signal (analog, or composite) to switch the aspect ratio on your particular television.
Feb 24, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Vizio P2 42 in. HD-Ready Plasma Television Logo
75 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
