Question about Acer V193w LCD Monitor
How do I adjust the color on monitor?
My monitor has a pink tone to it now? I just booted it up and it has changed from normal somehow.
    Top Expert:
  • Acer Master
  • 14,161 Answers
Instructions
  1. PC Monitor
    • 1Check the color balance options on your monitor. Typically, there is a button on the monitor itself that can be used to enter the Settings menu and configure color. The color balance may have somehow been changed, resulting in the pink image.
    • 2 Calibrate the color system for your monitor through Windows. Press "Windows-X" to open the Power User menu and select "Control Panel." In the Search bar, type "calibrate display" and click on "Calibrate Display Color" when it shows up. Provide your administrator password or confirmation if prompted.
    • Sponsored Links
    • 3 Check to see if the cable connecting the monitor to the computer is loose by lightly jiggling the connector at both points. If it's loose, this could be the cause of the display error. Secure the connection and see if the issue has cleared up.
    • 4 Check the connectors themselves for bent or damaged pins. A damaged pin can cause a faulty connection, which can lead to errors like a pink-tinted screen. If the pins are just bent, you can try to bend them back into place with a pair of needle nose pliers. If they are otherwise damaged or missing, you'll have to replace the cable itself.
    • 5 Perform a factory reset of your monitor if replacing the cable has not repaired the issue. Instructions for a factory reset vary from one model and manufacturer to the next, so consult your owner's guide for detailed instructions.
    • 6 Connect your computer to a different monitor if the problem persists after factory reset. If the problem persists with a new monitor, the issue is likely with your video card. If this is the case, consult the card's manufacturer for detailed diagnosis and assistance. If not, your monitor may be damaged and incapable of rendering a properly colored image. Take it to a repair professional for repair or replace it.
Read more : http://www.ehow.com/how_8446307_fix-color-pink-hue-everywhere.html
GOOD LUCK.
Posted on Dec 12, 2014
My monitor suddenly has a pink hue to it. HOw do you fix that?
hit the menu button and play around with your color options. It is likely that these somehow got adjusted.
Aug 26, 2011 | X2Gen Computers & Internet
@the monitor appearance changed to pink shade and we are not able to see in this colour pl give me a solution to sent it back to normal mode
probably the color setting of the monitor has been changed.
on the monitor panel press the menu button and go to the color option.
see if increasing or decreasing the RED GREEN and BLUE color options sets back the monitor to normal.
usually some monitors have a reset option also, by selecting it everything will get back to normal.
Aug 02, 2011 | Computers & Internet
The monitor color is pink...i want it to change to normal color...
Colors on the monitor are produced by mixing the three "primary" colours.
If the monitor is not producing one of those three colours, you can get "pink" instead of "white".
Fix the monitor, or replace the monitor, or replace the video-card (if using a different monitor also produces "pink").
Jun 21, 2011 | Computers & Internet
The color / hue on my sony monitor seems to be pink how do I adjust it to its normal color ?
Click on the link below and download the manual to know how to change settings of your monitor
Monitor Settings Manual
Regards,
Shawn
Feb 03, 2011 | Sony SDM-HS95 19" LCD Monitor
My hp monitor's colors are messed up.
Did you already try it on another PC?
Try new VGA cable?
Otherwise you may have to open it up and look inside for failed components.
http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | HP Vs17 17" LCD Flat Panel Monitor
LCM-22w3 monitor suddenly changed colors. All
Try adjusting the monitor cable that goes from your monitor to the back of your computer.
Jul 10, 2009 | Westinghouse Electric LCM-22W2 Monitor
Pictures on camera screen and on computer are pink now
sounds like the gamma settings need to be adjusted somehow you hit the wrong button and adjusted the gamma settings if you know the reset on your camera try reseting it
Dec 06, 2008 | HP Photosmart 945 Digital Camera
Monitor picture blurs out and dimming
Hey there chel wjd, My first guess is that your video card is faulty. I suggest you pull it and return your video connection to the onboard port. Ensure you make the necessary setting changes in the bios. If this solves your problem, get yourself another video card. Good Luck!
Jan 31, 2008 | Gateway FPD2275W LCD Monitor
Screen turn into pink (light rise color)
if you have the skill for take off the cover,take off the metal shield and cables until you reach the CRT board,have a 100watt light on,a solder hot iron in one hand and a few rings of tin in the other, obviously take off the plug and left it over a few meters,and waited a few minutes to give some capacitors discharge time,.............it's easy !!! resolder the joints that like dark,mainly see the big transistors,(or IC)that have like rings on it's pins, and thats all. I tell you its easy okay then you have to "rebuild" your monitor back.
Jul 09, 2007 | SAMTRON 55V 15" CRT Monitor
Monitor screen turned into pink
A defective monitor cable can cause the monitor to turn pink.
May 13, 2007 | SAMTRON 55V 15" CRT Monitor
Acer V193w LCD Monitor Logo
142 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
