Question about Water Heaters
How do you operate the water heater in a keystone zeppelin travel trailer
4 Suggested Answers
  • 201 Answers
SOURCE: Bought an old 1984 Terry Taurus Travel Trailer
see if control knob pushes in while in pilot posistion ,if so place in pilot posistion and keep depressed for at least 1minute after lighting pilot light then move to on ...gd luck chris
Posted on Jun 18, 2009
  • 332 Answers
SOURCE: 2007 hot water heater leaking
You will be happier if you replace it
Repairs seldom last very long with this type of problem
Posted on Mar 29, 2010
motor1258
  • 6674 Answers
SOURCE: Hot water heater is not working correctly on electric
Check that the by-pass valve(s) on or near back of water heater are in the proper position. If your stumped on how they should be for normal operation, remember this. Cold water has to flow into bottom of tank, so that valve needs to be open straight into that fitting. Then the hot comes out the top, so that valve has to be open as well. Any valves in between those lines need to be closed, otherwise it will mix cold and hot . If still not sure, get back to me, with location of any valves there, and I'll guide you through it.
Posted on Apr 25, 2010
Why hot water heater on my cedar creek travel
You needed to post more info. does it have power to the heater. Is it electric or gas? if electric and it has power to the heater you need to check with an electrical tester if there is power across the element terminals, If not it needs to be replaced
Oct 12, 2014 | Water Heaters
I would like to know how to turn on (run) 110 V for the water heater on a Conquest/Gulf Stream Travel Trailer?
Must be filled with water or elements burn out
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-water-heater-element.html
If water heater is plugged in and outlet has power... then water should be hot.
If no water inside tank, and tank is plugged in, and outlet has power, then element is burned out.
Gene
Sep 11, 2014 | Water Heaters
Tankless water heater for 2006 gulfstream cavalier travel trailer
What you really need to know is what the maximum flow rate and at what temperature you need. These do not store water, they heat it as it passes through.
Apr 09, 2014 | Water Heaters
Komfort 2003 travel trailer
There should be an ON /OFF switch inside, do you have power there? if you do you have a bad switch.
Apr 29, 2013 | Suburban Hot Water Heaters - All
I have a Atwood 10 gallon electric/ propane water heater on the Hornet travel trailer I purchased used. There are two switches on the wall, one is an on/off switch that lights up and the oither is just an...
The two switches control the water heater either in the gas or electric mode. The switch with the lights would be for the gas operation, and the switch without lights would be for the electric mode. Prior to operating either switch, make sure the water tank is full of water. Turn your hot water tap on, if water comes out, tank is full. Connect trailer to 110 Volt source, turn circuit breakers on, Place switch without lights to on position. If water does not heat in 45 minutes, Install new heat proble. The gas mode should be repaired by someone that is familiar with that system. Atwood can provide you with a local service center.
Oct 10, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Water Heater electronic ignition to work???
Here's a link to operators manual. You can download PDF file as well and print for later use if you wish.
http://bryantrv.com/docs2/docs/operating/atwood1.pdf
Apr 21, 2010 | RTO Atwood Water Heater - 6 Gal LP
Apr 12, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Mar 21, 2010 | RTO Atwood Water Heater - 6 Gal LP
Bought an old 1984 Terry Taurus Travel Trailer with no manuals and can not figure out how to start water heater
Jun 18, 2009 | Water Heaters
Water Heaters Logo
29 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
