SOURCE: I have an Electrolux Aerus 2100 canister vacuum. When I
it might be that the hose connections are bad.or it might be a sensor in the vacuum. call a electrolux vac shop and get it looked at.
SOURCE: 9 month old electrolux oxygen vacuum just quit
cheap vacuum made by eureka,
aerus is the hi end of electrolux.
google aerus
SOURCE: I broke the part that vacuums the carpet on my
Yes, you can fix you power nozzle. Just look at the parts diagram at the following link: http://evacuumstore.com/s-90-el7020a.aspx
This should help you find the part you need.
SOURCE: Electrolux el7020b is making a clicking noise?
You need to change the belt
http://evacuumstore.com/c-99-electrolux-belts.aspx?manufacturerfilterid=0
SOURCE: carpet rollers dont work
Hi There,
Yes, there is a reset switch on your Electrolux. This particular model also has some problems with the wands on the machine as well. Sometimes these wands will short out, preventing the power nozzle from working.
Try pushing the reset switch first to see if this fixes your problem. The reset switch is located on the power nozzle on the right hand side if you're looking down on it. It will be a little red pole, simply push this pole downwards, possible using a ball point pen is the easiest way.
If this didn't fix your problem, then it could be a few different things. The wands on your model are problematic, and should be the next thing that you test. Simply remove the wands from the power nozzle, and you can use a simply electrical tester purchased from Home Depot, and put the testers into the female receptacles on the end of each section of wand to ensure that power is getting down to the brush.
It may also be that your hose has gone bad. If you test both wand sections, and no power is getting through, remove both wand sections and test the female electrical connections on the end of the hose handle.
If you're not getting power here, this indicates that your hose has gone bad and needs to be replaced. We do carry all of the hoses for the Electrolux canisters, and most likely have the one for yours in stock. Please feel free to contact me if you need any further help.
Thank you,
Chris Jones
GoVacuum.com
Please clarify model. If this is older than 5 yaers your motor and or brush roll need to be removed cleaned and lubricated.Something is binding inside generally due to hair and dirt at the end of the brush roll. Do not continue to run the head in this condition
