Question about Hampton Bay 04383 Calibre Ceiling Fan
How do I install a remote control in a hunter ceiling fan
Buffalo12980
  • 625 Answers
SOURCE: Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Posted on Aug 22, 2007
SOURCE: reversing direction on remote controlled fan
There is no switch. Put the fan on high then hit the reverse button. Your fan should stop, reverse and you'll bet all set.
Posted on Nov 30, 2008
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
jmgldsmth
  • 1889 Answers
SOURCE: remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Posted on Apr 22, 2009
SOURCE: Hamilton Bay Remote Control Ceiling Fan
Rempte light comes on but does not activate fan or light?? thanks
Hunter fan 27227 remote stopped working
How i fixed my Hunter #28096 remote controlled ceiling fan, started not controlling the light, then later the fan quit also. Start by testing the remote buttons, see this post... Cp9430r Fixya
Jun 22, 2014 | Hunter Ceiling Fan Light Remote Control
Hunter ceiling fan remote 27144
reset the code and test again.
God bless you
Feb 18, 2013 | Hunter 27144 Universal Remote Controls...
I just installed a hunter ceiling fan with light & remote control but the fan will not shut off or change speeds
Sorry for this::::You may not have the correct remote for the fan.
The fans are difficult to install.
Kudos to you,Sir.
Nov 13, 2012 | Hunter 52" Ceiling Fan With Light And...
Instruction for a hunter remote model 27157
this is the hunter technical support--1-888-830-1326 just ask for support. then you should be able to order the instruction manual.
Nov 26, 2011 | Hunter 52" Ceiling Fan With Light And...
Need the manual for our ceiling fan, Hunter, Park
i have to fans close to each other i would like to change the code on the remote
Apr 24, 2010 | Hunter Ceiling Fan Light Remote Control
Im installing a hunter remote control receiver in the ceiling mount. I have a red, black, white and ground wire from the ceiling. Which wire on the reciever do I connect the red wire to?
The red wire in the ceiling is probably used in a shared neutral circuit and not needed for the fan. If it's not capped off already, it should be.
Just use black, white and ground from the ceiling.
Charlie
Aug 16, 2009 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan. Lights and fans turn on and off by themselves.Both fans are on the same wall switch and are operated by separate remotes.
I just installed a 2nd hunter fan model 23811 that also seems to be controlled by grimlins. If the power is left on, the light and fan randomly turn on and off. And no, it is not due to fans being on the same frequency. It appears to be an issue with the control module. I'm contacting Hunter.
Jul 26, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Fan and lights comes on automatically
· If you installed more than one remote-controlled ceiling fan, set the DIP switches on both receivers and the control of one fan to an identical alternate sequence (such as "all up" rather than "all down"). Otherwise, when you turn off the ceiling fan in one room, it will turn off the fan in the adjoining room. You can also go to the internet and enter GOOGLE.com in the GOOGLE search box enter Hunter.com homepage. You should find all the help you need there.
If you found any of this information helpful, please rate my solution. Thanks D. Lange
Apr 23, 2009 | Hunter Ceiling Fan Light Remote Control
Hunter Fan with Remote
Contact Hunter Fan and they will send you another ceiling remote. Just received mine but have not installed yet. Good luck. Len
Apr 27, 2008 | Hunter 52" Ceiling Fan With Light And...
Hampton Bay 04383 Calibre Ceiling Fan Logo
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
