Question about Abus Lock Padlock, 65/20 KA 202
Unlock abus 202
Lost my code, how to reset
I forgot my nokia asha 202 security code so plz help me...
Your default security code is 12345. If you change that then you need to reset your security code from flash box. Thanks
Dec 14, 2014 | Nokia Asha 202 Dual-SIM GSM Unlocked Black
How do i get i n h off of display of my radio shack htx 202
HTX-202 (190-1120) Error Codes Faxback Doc. # 15722 Your transceiver has two error code displays. Refer to the following for an explanation of each error code. Er1: INTERNAL RAM ERROR Er1 indicates the transceiver has detected an error in its battery-backed up operation memory. This is the most commonly caused by a low lithium backup battery, but can also be caused by static discharge, or a physical shock. To clear the error-- 1. Turn off the unit. 2. Press FUNCTION and CLR (the D key). 3. While holding these keys, turn unit on. This will reset unit and clear memories. If the transceiver frequently displays the error, have the battery replaced by an authorized Radio Shack service center. ER2:PLL UNLOCK ERROR Er2 indicates the transceiver's PPL section has unlocked. Have the transceiver repaired by an authorized Radio Shack service center. (/ir-07/31/95)
Nov 01, 2014 | Radio Communications
I use nokia 202 and i forget my secureity code please help me
This may help
cellphoneunlock.net/2012/03/23/how-to-unlock-nokia-asha-202/
Jun 22, 2014 | Cell Phones
Nokia asha 202
call service center of nokia with tat imei number they will tell you correct solution on your mobile.
Apr 29, 2014 | Cell Phones
Code to unlock real football 2013
It's based on users country, so please give me your country name...
Nov 29, 2013 | Nokia Asha 202 Dual-SIM GSM Unlocked Black
Lost code to unlock kingavon safe30
if you lost your security code you need to reset your phone. you can try resetting your phone through codes. its the safe way to reset your phone. because when you reset your phone through software or hardware there are possibilities for data getting corrupted or lost. but there is no such possibilities when you reset through codes. thats y i prefer this method to reset my phone. i got the codes from this site Unlock-Free.com to reset my phone. try it
Nov 14, 2011 | Cell Phones
Nokia 1650
sir i am nokia 1650 mobile lost my paasward so pls give master reset unlock code
May 29, 2010 | Nokia 1650 Cell Phone
Abus Lock Padlock, 65/20 KA 202 Logo
Top Abus Lock Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you an Abus Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
